Good chemical to remove salt grime from aluminum??
#197058
01/18/09 02:28 PM
01/18/09 02:28 PM
Posts: 528 D/FW
gts95
D/FW
I'm trying to clean up the aluminum components that have been exposed to salt grime on my late model Durango...not sure what the correct terminology is as I know that aluminum does not rust per se, but it has some sort of "crud" on it from being exposed to salty water, grime, etc. Kind of looks like a "mold". Like the water pump, heads, etc. Some sort of flaky buildup, I'm assuming from a reaction to the salt? You guys from states where the roads are salted in the winter should know what I'm talking about! Basically what I would like to do it power wash the undercarriage and engine to remove the crud and make the aluminum parts (as well as the painted/iron parts) clean up. Any tips? Thanks!
1970 Super Bee, WM21, 383, auto, FY1, a/c, project!
1971 Chrysler 300 2dr, U-code, console car
1980 Chrysler LeBaron LS Limited coupe
2008 Chrysler Aspen, HEMI
2011 Ram 3500 MegaCab, 6.7
Re: Good chemical to remove salt grime from aluminum??
[Re: 1_WILD_RT]
#197060
01/18/09 04:48 PM
01/18/09 04:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's called corrosion, same as rust but not on Iron.
When I was a sailor we used to do lots of corrosion control on salt crusted/corroded aluminum.
We sand blasted it and repainted with two part epoxy.
Don't think you're gonna find something you can use in a pressure washer that will acoomplish what you want.
[Re: Stanton]
#197062
01/19/09 12:40 PM
01/19/09 12:40 PM
Posts: 528 D/FW
gts95
D/FW
We see a lot of that in the great white north. You can try some of the acid-based aluminum cleaners to neutralize it and remove the corrosion but you're still going to be left with an ugly pitted surface which will need to be coated with something immediately. The parts have usually been clear anodized to begin with but its a poor defense against salt!
Well this is just my daily driver, nothing worth the expense or hassle of taking off parts and coating them. Just trying to clean off some of that corrosion so it at least looks decent.
I'll go by the hardware store today to see if they offer some aluminum cleaners....anyone else have suggestions?
thanks.
[Re: gts95]
#197063
01/19/09 01:40 PM
01/19/09 01:40 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
I use Aluminum Jelly from the same folks that make Naval Jelly. Paint it on intakes and slotted wheels and then hose it off and it shines them right up.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
