Oil pan options #1970424
12/15/15 08:21 PM
12/15/15 08:21 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
Wondering what oil pan options are out there. 67 A body, factory steering, K frame and TTI's. K frame is trimmed a bunch for clearance.
Milodon 31000 seems to be common but i'd like more capacity and depth without having to add an accumulator.
Charlies offers a pan but it doesn't appear any deeper than the Milodon.
Anything else i'm missing?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Oil pan options [Re: Triple Threat] #1970456
12/15/15 09:18 PM
12/15/15 09:18 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
stock truck pan is rear sump and an inch deeper than 3100.
IMO the 3100 is a POS i am switching to this, my 3100 and pick up is for sale..cheap
http://www.ebay.com/itm/351228204068?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: Oil pan options [Re: Triple Threat] #1970789
12/16/15 12:27 PM
12/16/15 12:27 PM
Renton Washington
Renton Washington
Will the rear sump clear the center link? or do you have an aftermarket front end?
-Dustin
Re: Oil pan options [Re: Triple Threat] #1970839
12/16/15 02:00 PM
12/16/15 02:00 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Waiting...waiting
Re: Oil pan options [Re: Triple Threat] #1970840
12/16/15 02:04 PM
12/16/15 02:04 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
i do hav an aftermarket front end
Re: Oil pan options [Re: Triple Threat] #1970878
12/16/15 03:09 PM
12/16/15 03:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Someone needs to make a 10-11qt deep drag race center sump pan for the Gen III in old Mopars.
Mopar to the bone!!!
Re: Oil pan options [Re: 72Swinger] #1970893
12/16/15 03:31 PM
12/16/15 03:31 PM
Renton Washington
Renton Washington
Exactly what I'm after. Heck I'd settle for 8-9 at this point. It's sad the aftermarket makes 6 quart pans and the truck pans are 7 qt from the factory.
-Dustin
Re: Oil pan options [Re: Triple Threat] #1970917
12/16/15 04:07 PM
12/16/15 04:07 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I just bought a truck pan and pickup off ebay for $50. My plan is to cut the front of the sump out and add extra capacity.
While I have not had any issues that I know of with the Milodan pan, I think they dropped the ball and could have made it a little deeper.
But I also have a rack and pinion on my car
Re: Oil pan options [Re: sixpackgut] #1970920
12/16/15 04:13 PM
12/16/15 04:13 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Barton sells this moroso oil pan for his Drag Pac cars
Re: Oil pan options [Re: sixpackgut] #1970937
12/16/15 04:57 PM
12/16/15 04:57 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
little FYI BES is doing all dragpack motors now..
Re: Oil pan options [Re: Triple Threat] #1970993
12/16/15 06:30 PM
12/16/15 06:30 PM
Renton Washington
Renton Washington
Guess I might have to crawl under my daily driver (2010 2500 Ram) and take some oil pan measurements.
-Dustin
Re: Oil pan options [Re: Triple Threat] #1972432
12/18/15 11:22 PM
12/18/15 11:22 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I ran into the same problem. I ran my engine out of oil on the top end of the track at 7000+ with a 6 quart pan. I took a Milodon pan, cut the sump, and extended it. I run 10 quarts in my system with remote mount filter setup. 8 in the pan and a quart in each oil filter and never had an issue again.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: Oil pan options [Re: Hemijoejr] #1972619
12/19/15 12:01 PM
12/19/15 12:01 PM
Canada
onig Offline
onig  Offline
Canada
Do you have a pic of your modified pan?
69 Dart
Re: Oil pan options [Re: Hemijoejr] #1973046
12/20/15 12:04 AM
12/20/15 12:04 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Setting here thinking, where is all that oil accumulating up in the engine? I would look at the drain back holes instead of just pumping more oil up there. How much oil pressure do you have at 7000, should be no more than 70.? What viscosity? Now that you said that I'll do a visual on mine tonite.
Re: Oil pan options [Re: Triple Threat] #1973060
12/20/15 12:32 AM
12/20/15 12:32 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The exhaust valves and rockers were designed to be oiled via that side of the head FILLING with oil. Intake rockers have oil holes aimed at the valve tips, exhaust sides have none. Its not the most ingenious design IMO but if you create rapid drainback you might end up with blued exhaust rockers.
Re: Oil pan options [Re: Triple Threat] #1973377
12/20/15 05:33 PM
12/20/15 05:33 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I have 75lbs if oil pressure at 7000 with 10w-40. I have to see if I can dig up some pictures tonight. I freshened the engine up 6 years ago so I have to see if I can find the pictures.
Re: Oil pan options [Re: 72Swinger] #1974632
12/22/15 03:31 PM
12/22/15 03:31 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Rockers and springs oscillating in a bath of oil, might as well put them in a blender, I can see a lot of foaming. Surely they could have come up with some type of spray out of the shaft or rocker arm.
Re: Oil pan options [Re: 72Swinger] #1975084
12/23/15 11:51 AM
12/23/15 11:51 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I have never heard that before and there is no way that could be true. That would require 5 qts of oil.
and for the record, Ray Barton told me they are only running 7qts in there 950hp 9000+ rpm engine. They do restrict oil but wasn't exactly specific on the details
Re: Oil pan options [Re: Triple Threat] #1975213
12/23/15 03:40 PM
12/23/15 03:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look at the exhaust rockers, no oil passage to valve tips. They get oiled from splash/submersion.
Re: Oil pan options [Re: 72Swinger] #1975286
12/23/15 05:43 PM
12/23/15 05:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Yes, that is possible but not fill the head
