99 ram wont start #1970333
12/15/15 07:19 PM
12/15/15 07:19 PM
Iowa
coronetville Offline OP
Iowa
Need some good help on this one. Bought 1999 2500 that had
Quit running, before that the truck would either start or not start. So I shot some starting fluid in and the truck started and ran as long as the fluid was used So I replaced the fuel pump Got the truck to start and ran great, but when I tried to restart it ,would only start when you let the key go back to start (on). So I put in a new ignition switch
now it wont start. What should I do next?
Re: 99 ram wont start [Re: coronetville] #1970662
12/16/15 02:59 AM
12/16/15 02:59 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Read the thread titled "Roll over valve- Updated" and follow the test procedures listed there. I'm too lazy to retype my answer. Gene
Re: 99 ram wont start [Re: coronetville] #1970713
12/16/15 09:15 AM
12/16/15 09:15 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Check the fuse inside the cab. fuse panel mark engine it's an 10 amp. fuse.
