Page 12 of 45 1 2 10 11 12 13 14 44 45
Re: Trick Flow heads [Re: fast68plymouth] #1969524
12/14/15 04:29 PM
12/14/15 04:29 PM
AndyF Online content
AndyF  Online Content
I should add that the Moroso valve cover gaskets don't work with the MP valve covers. The MP valve covers cut the Moroso gaskets and ruin them.
I've used the Moroso gaskets with the Indy cast covers for years without any problems but the MP valve covers ruined the Moroso gaskets almost immediately. I switched back to the thick black FelPro gaskets for the rest of the dyno session.
Re: Trick Flow heads [Re: AndyF] #1969747
12/14/15 10:25 PM
12/14/15 10:25 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Andy I have those gaskets and MP valve covers and haven't had any issues. My MP covers are at least 10 yrs old. Do you know if MP may have changed the valve cover. Not questioning what happened to you just wondering out loud. Thanks
Ok
Re: Trick Flow heads [Re: fast68plymouth] #1969786
12/14/15 11:10 PM
12/14/15 11:10 PM
Do you have Trick Flow heads? It appears to me that the valve cover and the head don't line up so the gasket is in shear. The rubber can't handle the load and splits. A thick fiber gasket can handle the shear load.
Re: Trick Flow heads [Re: fast68plymouth] #1969914
12/15/15 01:55 AM
12/15/15 01:55 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
What's the preferred valley pan to use with aftermarket heads?
See 440 Source, Hughes, Indy, etc. all have options to choose from....thoughts?
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: fast68plymouth] #1970002
12/15/15 05:52 AM
12/15/15 05:52 AM
MD
HEMI472 Offline
HEMI472  Offline
MD
how much horsepower can be made with these heads ?? I don't see dyno numbers?? thanks Ed
Re: Trick Flow heads [Re: HEMI472] #1970146
12/15/15 02:03 PM
12/15/15 02:03 PM
330 cfm will make 650 to 700 hp depending on the rest of the combo. 600 hp should be fairly easy to make with pump gas and street/strip type cam. Trick Flow posted dyno numbers for their test engine.
Re: Trick Flow heads [Re: B Dartman] #1970149
12/15/15 02:04 PM
12/15/15 02:04 PM
I used a stock tin valley pan with gaskets glued to each side.
Re: Trick Flow heads [Re: AndyF] #1970292
12/15/15 06:03 PM
12/15/15 06:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. shruggy
Re: Trick Flow heads [Re: dartman366] #1970321
12/15/15 06:56 PM
12/15/15 06:56 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I used a stock tin valley pan with gaskets glued to each side. [/quote]for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. shruggy [/quote]
I am curious how this works out . Keep us informed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: AndyF] #1970391
12/15/15 08:45 PM
12/15/15 08:45 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Thanks Andy. So the issue seems to be a combo of the head and VC. I wasnt sure from the 1st post if that was the case or if something with the VC changed.
Ok
Re: Trick Flow heads [Re: tex013] #1970433
12/15/15 09:38 PM
12/15/15 09:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tex [/quote]
Didn`t work for me but maybe you`ll have better luck.......
Re: Trick Flow heads [Re: Thumperdart] #1970470
12/15/15 10:32 PM
12/15/15 10:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Tex [/quote]
Didn`t work for me but maybe you`ll have better luck....... [/quote]awww crap, that don't sound very incouraging,,what did or didn't it do, so I know what to expect.
Re: Trick Flow heads [Re: dartman366] #1970490
12/15/15 10:51 PM
12/15/15 10:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tried it on my buddy`s 512 years ago and no matter what we did it leaked BADLY and we even tried the "Right stuff".......
Re: Trick Flow heads [Re: Thumperdart] #1971071
12/16/15 09:17 PM
12/16/15 09:17 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Same here. Waste of damn $ but of course they'll blame it on your install. Funny how I've never had any other valley pan leak. Save yourself some time and $. My 2 cents.
Re: Trick Flow heads [Re: fast68plymouth] #1971331
12/17/15 08:55 AM
12/17/15 08:55 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Have to say I'm impressed with TF's response to customer feedback. Much better than other suppliers whose attitude seems to be "you will buy our half assed product and like it."
"I think its got a hemi"
Re: Trick Flow heads [Re: Thumperdart] #1971489
12/17/15 04:03 PM
12/17/15 04:03 PM
Me too, I installed one on a good freind of mines motor, it always leaked runaway down I have heard since then that if you remove the powder coating on the sealing surfaces and then use a good sealant it will seal. I haven't done that so who really knows or not confused shruggy IHTHs thumbs
Re: Trick Flow heads [Re: fast68plymouth] #1971534
12/17/15 05:26 PM
12/17/15 05:26 PM
New Zealand
dart6 Offline
dart6  Offline
New Zealand
this is confusing, what didn't work, was it the factory or hughes pan
Re: Trick Flow heads [Re: fast68plymouth] #1971563
12/17/15 06:23 PM
12/17/15 06:23 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
The Hughes pan
Re: Trick Flow heads [Re: Charger453] #1971581
12/17/15 06:49 PM
12/17/15 06:49 PM
Originally Posted By Charger453
The Hughes pan
iagreeDominic was the same part number. In fact my freind ended up trying a one piece steel 440 Source valley pan on his motor with the B1-BS M.W. ported heads and he stil had problems getting it to seal up with the Right Stuff work shruggy The thicker cast and billet aluminum valley covers don't seem to have that problems as much work shruggy
Re: Trick Flow heads [Re: Cab_Burge] #1971591
12/17/15 07:03 PM
12/17/15 07:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The Hughes pan
Note to self: don't try to save a few bucks on lower priced part's,,guess I just added one more item to the swap meet pile.lol
