Re: Ok guys let's hear how to make 850hp low deck -1 heads
[Re: earthmover]
#1969743
12/14/15 10:19 PM
12/14/15 10:19 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you are going with an after market block WHY are you setting the limits with a low deck block???
[Re: earthmover]
#1969851
12/15/15 12:25 AM
12/15/15 12:25 AM
Posts: 9,849 MI, usa
dvw
MI, usa
Mines never been dynoed. Runs 9.0-9.1/147-149 @ 3350lbs, 4.10, 10.5x31, foot brake. Best 9.02@151. Tall deck Mega block 4.5x4.5,-1 from Modern cut to 58cc, Comp .471" lobe 285/292 on 112 LCA in at 108,T&D 1.7,Trend 7/16 tapered, Flat top .043" ring, 14.8-1, Indy cross ram with either Holley or Eddy 750's,GZ pump, out of the box 2 1/8" Hookers. My bet is a good single plane and Dominator would be quicker. Probably would like a bigger header and more gear as well. Never run it past 7000-7100. Doug
[Re: earthmover]
#1969854
12/15/15 12:29 AM
12/15/15 12:29 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I went with a shorter stroke 4.15 crank and 4.5 bore to make 528 cubes which at the time I felt matched the 440-1 heads well. I really don't have much info to go on other than my own best ETs and a preliminary dyno sheet. Made 847 hp with a lousy dragster pan and only one inch vacuum. 800 hp at 5700 rpm, max power from 6400 to 7000 rpm within ten hp or less. A new pan and better cam after the dyno session lowered the ET some. My 440-1 heads are the early versions, so I assume there is a bit more power in the newer version. I run Alky, Terminater injector, 3X intake, .775 lift roller, 62 cc chambers,15/1 compression, Very short dome, (.080?) full porting. Jesel vlave train. I am eventually going to go with 1.7 ratio rockers I have. Best ET was 8.77 at 153 mph, at altitude and 3055 pounds with a TF. You can go either way, low deck or hi, but the low deck eliminates the 3x intake and any tunnelram but a custom made piece. The low deck will be a bit lighter, and a little narrower in the chassis. If you are willing to consider budgeting for them, going with a high dollar block begs for better heads. Your basic upper limit will be 850 to 900 hp with the 440-1 heads, and there is another 150 hp possible if you switch to B1Mc heads.
[Re: earthmover]
#1969888
12/15/15 01:28 AM
12/15/15 01:28 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I've had two motors that made close (526 C.I.high compression bracket motor 440 block that made 845 HP on race gas and 518 C.I.,10.78 to 1 comp. ratio 400 block 775 HP on pump gas Both motors where dyno tested on a DTS engine dyno in Klamath Falls, OR which is at 4300 Ft elevation, I don't remebmer the uncorrected numbers now but the pump gas motor ran faster,9.993 at 134.+ MPH through the full 3 inch exhaust on Oregon 91 octane pump swill than my 3450 lb Duster was legal for ) to your goals with the same set of 440-1 CNC ported by Jeff at MCH. That set of heads had the 2.250 intake valves and the standard size ehaust valves, those heads flowed right at 370 CFM at .700 lift. I'm building another, better, 400 block 518 C.I. bracket motor now with a vacume pump and a set of CNC ported 440-1 with Jesel paired shaft rockers, I'm hopng it will make real close to 900 HP on E85 with one carb.
[Re: earthmover]
#1970010
12/15/15 08:16 AM
12/15/15 08:16 AM
Quicktree
I have been thinking on the b1 deal..wish I would have made that move in the beginning. ..
This is what I have in the car now . 451 lo deck 13.1 alky 737 705 roller td 1.6 rockers custom headers 2.25 into 4inch collectors 727 8in 5600 versa ford 9in 456 gear 31/15 mt slicks tube chassis 73 duster hopefully about 2400lbs glass front doors Truck back bumper lexan all around all aluminum int...my son will be learning with this set up but I know we are way behind in power now days around here...not trying to be the fastest but not the slowest either. ....I'm looking at a build for 2016 and would like to start collecting parts..around here now if your not 50 or faster your kinda in the way..saw about 3 4 4sec. Cars Saturday night just testing. .1 been 442 and shut it down got on intercom told everybody they can get the back tire grudge race run your car not your mouth ..not trying to be that fast but 50 on muscle is a good start .. find a race block first
[Re: earthmover]
#1970180
12/15/15 02:56 PM
12/15/15 02:56 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
World block, 4.5x4.5(572), 14:1. Indy 440-1 CNC 345, Jesel 1.7, .780 cam, no vacuum pump. Heads flowed 377/282 @ .750
440-2/440-2A with 1150 - 786tq/872hp Indy TR, 2 x 750's - 811tq/911hp
9.04 @ 148 at 3660lbs
[Re: earthmover]
#1970484
12/15/15 10:46 PM
12/15/15 10:46 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Two ways RPM or Cubes. Most choose the cube way as it is less money and maintenance
[Re: earthmover]
#1970640
12/16/15 02:06 AM
12/16/15 02:06 AM
gregsdart
My chosen engine shop that does my machine work wasn't afraid to tell me to go a full 4.500 bore right from the start. His opinion is take care of the motor well, and when it loosens up after a few rebuilds, hone it out to 4.502 or what ever the smallest it will clean up and order new pistons. You can do it again down the road if you still have the same motor. With rings being available in .005 over, as long as piston makers will custom make a slightly bigger piston, you can get a lot of life out of a Mopar 4.8 bs block.
[Re: rickseeman]
#1970822
12/16/15 02:39 PM
12/16/15 02:39 PM
Posts: 368 michigan
turbo toad
michigan
Says there taking orders for the KP block did any else pick up on that fact?
Check out my build on Facebook Ttoad Hurley its updated regularly
