brake conversion 68 charger #196961
01/18/09 09:58 AM
01/18/09 09:58 AM
norton mass
scotman1955 Offline OP
norton mass
i have spindles off a 1975 dodge dart i am trying to find out what year calipers and rotors will work with these spindles and my 68 charger
Re: brake conversion 68 charger [Re: scotman1955] #196962
01/18/09 11:12 AM
01/18/09 11:12 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
73-76 A-body parts are what you need. Dart, Duster, Demon all the same stuff for that spindle...Im doing it now on my 70 Sport Satellite...:)
Re: brake conversion 68 charger [Re: scotman1955] #196963
01/18/09 12:03 PM
01/18/09 12:03 PM
I would suggest that you use the 11&3/4" rotors & the required adapters(I'd use sliders) & some better pads & follow a bed in procedure. the larger ones are not too $$$ nor hard to come by & make a big difference in what you end with for braking. If not as said the 73-76 A body & 73-74 E body 10.87" rotors/adapters are what you need to find. EDIT the 76 (only) A body calipers have about a 5/32" larger bore than the 73-75 calipers which gives you better brake bias. The external dimentions are the same as is the price.
Re: brake conversion 68 charger [Re: RapidRobert] #196964
01/18/09 01:12 PM
01/18/09 01:12 PM
BDW Online content
BDW  Online Content
Re: brake conversion 68 charger [Re: scotman1955] #196965
01/18/09 01:20 PM
01/18/09 01:20 PM
AndyF Offline
AndyF  Offline
For a '68 B body car you probably want to hang the calipers to the rear. In that case I'd use the late model FMJ calipers since they are designed to be rear hung. They have the inlet and bleeds in the correct location to be rear hung. Then you'll need to have a set of custom brakes hoses built and you'll be all set.
Re: brake conversion 68 charger [Re: AndyF] #196966
01/18/09 01:43 PM
01/18/09 01:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I run the 73 Up A body spindles and 11.75" Cordoba rotors with AndyF's Wilwood adaptors and the the Late model Aluminum M/C....works phenominally.
I'd like to know if there is really any weight savings though...the WW calipers are super light but those big rotors seemed about as heavy as the drums and backing plates that were on there. With the oem calipers I'd almost bet it's heavier overall.
WIZE
In Car:
Re: brake conversion 68 charger [Re: Streetwize] #196967
01/18/09 05:12 PM
01/18/09 05:12 PM
BDW Online content
BDW  Online Content
I bought eveything for my Challenger at local Advanced Auto. If you order online, you'll get free shipping.
raybestos w/pad RC4103/4 $36.00
78 charger 2.75" (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorfman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
