HEMI K Frame differences???
#1969616
12/14/15 06:32 PM
12/14/15 06:32 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
If I copy the motor mount provisions off a 68 or 69 B Body HEMI K member and locate them on the exact same spots on an E Body K frame after I shave off the regular V8 mounts, would I have a K frame that locates the HEMI in the correct spot for an E Body?????
I am asking this because I heard sometime that the actual steel HEMI motor mounts (the left and right units that bolt on the block and then to the insulators) were different between years and bodystyles. I always thought they were all the same. Im not 100% sure if this is true though!!!
So having said that, I was wondering if the K frame HEMI motor mount provisions on the 68-69 and 70-71 E Body HEMI K frames would be basically the same or would they vary?
Im trying to make me a repro E Body HEMI K frame using a regular V8 E Body K frame and a 68/69 B Body HEMI K frame as a template to copy from....
Re: HEMI K Frame differences???
[Re: domingo]
#1969665
12/14/15 07:56 PM
12/14/15 07:56 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I believe that there are only 3 K-frames for an E-body. - 6cyl/small block - Big block - Hemi/Six-pack
The only difference between the k-frames on a hemi/six-pack car and the regular big block k-frame is that the hemi's and six-pack got a skid plate (to protect the oil pan) and a small metal "coin" welded onto the front edge, driver's side.
Bottom line is start with a big block k-frame. You can buy the skid plate (reproduced) and make a fake "coin" pretty easily (if you're trying to look original). B-body & E-body k-frames are the same.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: domingo]
#1969679
12/14/15 08:21 PM
12/14/15 08:21 PM
Posts: 3,141 tennessee,usa
mattsmopars
tennessee,usa
mega parts list their repro hemi K frame as 71-72 B body and 70-74 E body. I would think the upper K frame portion of the mounts would be basically the same as the 66-69 B body hemi K frame. As you mention they have different skid plates and different sway bar mounts. I think the metal engine mounts vary between year and body but the rubber isolators are about the same. Matt
[Re: domingo]
#1969793
12/14/15 11:12 PM
12/14/15 11:12 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Al Debevec mods them, gave the information and patterns to Mega parts, now they are modding them too. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
