Steering coupler spring, early vs. late? #1969143
12/13/15 09:32 PM
12/13/15 09:32 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
I bought a steering coupler rebuild kit for my 1966 Coronet. The spring that keeps the shoes against the housing has a large radius "bump" on the top that prevents it from fitting inside the coupler housing. I see ONE and only ONE reference to this on the internet. It seems that the coupler housing and spring are different prior to 1966. Does anyone know where to go to find an early kit for a coupler rebuild?
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1969151
12/13/15 10:00 PM
12/13/15 10:00 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do the new shoes fit and if so can you reuse your old spring , assuming it's not destroyed ?
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1969152
12/13/15 10:01 PM
12/13/15 10:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1969218
12/13/15 11:56 PM
12/13/15 11:56 PM
chicago,il
jaque Offline
jaque  Offline
chicago,il
steer n gear!! they have a newer style with boot i just used and worked great!
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
Re: Steering coupler spring, early vs. late? [Re: jaque] #1969356
12/14/15 09:25 AM
12/14/15 09:25 AM
Tennessee
Tennessee
Unfortunately, I am starting from scratch on this project and don't have the old spring. Steer & Gear looks promising, THANKS
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1969392
12/14/15 12:34 PM
12/14/15 12:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If you have power steering 2530540 should be the part number you need for the spring. Apparently you need two of them. http://arizonaparts.com/ and https://bradsnosparts.com/product/2530540/ should have it.
Re: Steering coupler spring, early vs. late? [Re: mopars4ever] #1971210
12/17/15 12:50 AM
12/17/15 12:50 AM
Tennessee
Tennessee
Thanks for the info. Due to the suggestions on here, I called Steer & Gear. They sell a complete unit with an improved seal. I placed the order today. Again, thanks for the help from all of you, I didn't know about most of these sources.
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1971242
12/17/15 01:38 AM
12/17/15 01:38 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Does anyone know a source for these early flat-style springs? The one on the left.
Re: Steering coupler spring, early vs. late? [Re: Hemi ragtop] #1971403
12/17/15 01:25 PM
12/17/15 01:25 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The steer and gear redesigned seal/boot does'nt hold up and cracks prematurely...Many have complained about this... twocents
