Re: 1974 w200 440 4 speed fuel mileage questions.
[Re: Quicksilver440]
#1968915
12/13/15 01:48 PM
12/13/15 01:48 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
Pulling a trailer... I'd say carry a spare 5 gallons of fuel to be safe. Fixed. On a serious note, single digits definitely. Have you ever pulled anything with the truck before? How a truck runs unloaded can be a huge difference from when it's loaded.
John
[Re: magnum440d100]
#1968920
12/13/15 02:00 PM
12/13/15 02:00 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
No I haven't pulled anything this heavy. Only a 5x8 landscape trailer.
I had initially calculated 6mpg. But that means I'll need $300 to get there.
But I do believe it gets better gas mileage than I initially thought. With the gas gauge broken, and speedo broken, I pumped 16 gallons to go roughly 70 miles (figuring on 6 mpg). But I made it there, and back, and did a tremendous amount of driving before pumping gas again. I pumped according to 6mpg, and drove. When I pulled the fuel level sending unit out to swap it, I though my tank was empty. I was afraid to run it for fear of running out. But to my surprise, it was half full. Unloaded, the truck seems to get about 11-12. I'm going to fill up a gas can. Drive the truck until empty, and fill from the gas can. Then run it dry again.
Or possibly filling up, then driving for a distance, and pumping at the same pump. Hopefully it clicks off at the same point both times.
[Re: magnum440d100]
#1969313
12/14/15 02:36 AM
12/14/15 02:36 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Keep in mind the speed you drive is going to have a huge affect. Your truck at 55 versus your truck at 75 is a huge difference. If you kept it at 55 I bet you can get the 10mpg. At 75, no way!
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#1969334
12/14/15 04:07 AM
12/14/15 04:07 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
-Jon Try inputting your trips and fuel ups on fuelly.com to get a real world estimate of how your truck is performing. I did this with my daily driver and found out that my MPG gauge projects my car gets 1 mpg more than what I'm filling at the pump. I'm assuming your odometer is working.
[Re: magnum440d100]
#1969756
12/14/15 10:35 PM
12/14/15 10:35 PM
Posts: 5,846 ohio
ruderunner
ohio
My 77 w300 with 360 gets 8 empty. Runs out of rpm by 60 MPH.
I think you're initial estimate was righjht on the money for pulling a trailer.
Make your friend pay for the gas.
Angry white pureblood male
[Re: DaytonaTurbo]
#1969924
12/15/15 02:10 AM
12/15/15 02:10 AM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
Pulling a 20' enclosed? I'd calculate at 6mpg and be happy if you exceed that. I think 8 is realistic, 10 is pushing it IMO. This one! I've had a few big block Dodge trucks. 7-8 mpg if your working them (which pulling an enclosed trailer will be doing), and hope for a tail wind! If your pulling a loaded box, that's taller & wider then the truck, into the wind, its going to suck down even more gas. If your tires are sun checked, I suggest you change them before you leave! Trying to buy Dodge 16.5 tires on the road won't be any fun. Driving 600+ miles on sun checked tires is asking for trouble. Sun checked tires around town might work out OK, but for hours at a time on the highway? No way! Just my opinion. Been there, done that. Gene
[Re: moparmarks]
#1992319
01/17/16 12:04 AM
01/17/16 12:04 AM
Posts: 1,892 Spahn Ranch
RMCHRGR
Spahn Ranch
So you averaged 10.8 mpg. Not bad. I agree, that's good. My D100 2wd 400/4speed gets 9 mpg unloaded.
'71 Duster '72 Challenger '17 Ram 1500
[Re: poorboy]
#1993497
01/18/16 07:12 PM
01/18/16 07:12 PM
magnum440d100
woodcrest, CA
I would replace the intake bathtub gasket. I've had more the one big block suck oil up into the intake runners from under that tin gasket, and I've had more the one leak at any one, or all 4 corners at the head to block corners when driving highway speeds or turning higher rpms. Gene Valley pan gaskets are new. I used fiber gaskets on either side of the valley pan. Only thing I can think of is one bolt wouldn't torque to spec. It torqued to 25ftlbs but would not torque above that. Hmm
[Re: WO23Coronet]
#1994592
01/20/16 01:08 AM
01/20/16 01:08 AM
poorboy
Freeport IL USA
How do you seal the mating faces? Silicone? Yes, the blue stuff, on both sides of the head surface on the tin plate and on the block and corners of the block/head. Gene
[Re: WO23Coronet]
#1994812
01/20/16 12:21 PM
01/20/16 12:21 PM
DaytonaTurbo
Manitoba, Canada
How do you seal the mating faces? Silicone? I only use silicone under the front and real valley pan hold downs. Under the intake flanges I just mask them off and spray them with the copper gasket spray.
