727 input shaft end play measurement ? #1968643
12/12/15 11:02 PM
12/12/15 11:02 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
What is the correct way to measure end play on the input shaft?? If I stand the trans on the tailshaft it's very difficult to get an accurate measurement. With the trans horizontal and the tailshaft pushed back along with the input shaft, when I pull the input shaft forward on the dial I'm reading .045 ??????
Re: 727 input shaft end play measurement ? [Re: ccdave] #1968659
12/12/15 11:30 PM
12/12/15 11:30 PM
NC
440Jim Offline
440Jim  Offline
NC
I attached the page from my 1973 factory service manual.
IMO, although the two methods you mentioned give slightly different numbers, the main point is to take the measurement both before you take it apart and after you put it back together.
IMO, 0.045" is just fine.
Re: 727 input shaft end play measurement ? [Re: 440Jim] #1968678
12/12/15 11:50 PM
12/12/15 11:50 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Thanks Jim👍
