Starter Assembly Barrel Screws 1970 #1968635
12/12/15 10:57 PM
12/12/15 10:57 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I won't bore you with the details but I couldn't for the life of me get the screws out of the starter motor assembly barrel, so I had to drill them out.
So the question is where do I find replacement screws?
They should be the 3/8-16 x .66L, flat, phillips 60 degree head.
Appreciate the help locating.
Re: Starter Assembly Barrel Screws 1970 [Re: AAR#2] #1968714
12/13/15 12:33 AM
12/13/15 12:33 AM
MD
floyd Offline
floyd  Offline
MD
Check with Jim Ridge at Dixie Restorations
Dixie Restorations
111 Aull Street, Pomaria, South Carolina 29126
(803) 924-6247
http://www.dixierestorationparts.com/
