500 inch b1 carb size
#1968542
12/12/15 07:45 PM
12/12/15 07:45 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
What is the average carb size on a b1 original engine. I am currently running my 1050 pro systems I had built for my old w5 small block a few years ago. I'm just wondering if there's any hp to be gained with a bigger carb.i always run nitrous so I'm not really interested in every ounce of n/a power but if I'm way undercarbed it would be worth the cost to buy a new one
82' dodge pickup with a 499 low deck
Re: 500 inch b1 carb size
[Re: JesseR]
#1968551
12/12/15 08:09 PM
12/12/15 08:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Depending on RPM but it could go as high as a 1250... or a tunnel ram with 2 1050s for max air flow... you can get enough fuel in.. its always the air flow that lacks.. I was gonna go 2 1050s on a tunnel ram on my 514ci
[Re: MR_P_BODY]
#1968598
12/12/15 09:54 PM
12/12/15 09:54 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
Depending on RPM but it could go as high as a 1250... or a tunnel ram with 2 1050s for max air flow... you can get enough fuel in.. its always the air flow that lacks.. I saw 30 HP gain going from a single 1050 Dominator on a Indy 440-3 intake to two 1050 Dominators, one was the same carb, on a Indy dual 4500 tunnel ram intake I was disappointed with those results That motor made 775 HP with the single carb, intake and 1.5 inch Wilson manifold reversion spacer, it made 805 HP with the dual dominators, not sorted out though I have good freind who ran a heads up NOS class out here on the west coast for years and years(20+), I encourage him to make as much power as he could N/A and then add as much NOS as needed to win the races, set low ET and MPH and qualify #1 so he got all the money he could earn at each race to help him on his racing expences. He did that for years after that and won the sereis championship in his class a bunch of years
[Re: JesseR]
#1968719
12/13/15 12:39 AM
12/13/15 12:39 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When you push the button the amount of air going through the carb really drops off. The more you spray, the more it drops off. I would think on a 500" motor, that a 1050 would be plenty once the button has been pushed.
[Re: Viper469]
#1968728
12/13/15 12:57 AM
12/13/15 12:57 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
two 1050's are going on my 528 ci. if i was using a single carb i probably would have used an 1150. That is stunning Viper, What intake is that ? looks like $$$$$, love it.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: JesseR]
#1968733
12/13/15 01:14 AM
12/13/15 01:14 AM
ozymaxwedge
Australia
Thought my new Indy looked good......... well it did until I seen yours .
[Re: Viper469]
#1968836
12/13/15 10:23 AM
12/13/15 10:23 AM
Posts: 16,928 NC
440Jim
NC
It's one of john marcella's work's of art
Very nice. Are those O-ring seals for the carbs? what was the price?
[Re: racerx]
#1968859
12/13/15 11:28 AM
12/13/15 11:28 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
B1's flow about 5 percent more ?, and have bigger runner volume. I forget how much, but the Mcfarland formula puts them over 500 rpm higher for peak torque over a good set of 440-1 heads, depending on short block size.
[Re: racerx]
#1968861
12/13/15 11:32 AM
12/13/15 11:32 AM
JesseR
Mountain City, TN
Pro systems wants to build me an 1175 for it, I just want some real world comparisons from guys that don't want to sell me a carb first. I don't have a lot of info on the b1s as I bought this engine complete and it does like a little rpm, I shift it at 7400, but I run a glide so only one shift.
[Re: JesseR]
#1968916
12/13/15 01:52 PM
12/13/15 01:52 PM
Posts: 304 Florida
Mark Whitener
As long as what you have works for you keep it, size is about right.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: fast68plymouth]
#1968930
12/13/15 02:24 PM
12/13/15 02:24 PM
Thumperdart
State of confusion
When you push the button the amount of air going through the carb really drops off. The more you spray, the more it drops off. I would think on a 500" motor, that a 1050 would be plenty once the button has been pushed. Yep, I have 3 mid 8-second cars w/1050`s and spray.......
[Re: JesseR]
#1970273
12/15/15 05:33 PM
12/15/15 05:33 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Agreed steer clear of the Holly or equivelant 1250 shelf stuff for sure. They have to much throttle blade.
FWIW my 525 B1 had a 2.100 Throttle blade and made right at 1100hp. CFM wise it was in the 1180cfm range. I prefer three circuit carbs myself as it fits what I do. Some will argue that point and I understand their reasons, bit for me I prefer the third circuit.
[Re: Al_Alguire]
#1970283
12/15/15 05:44 PM
12/15/15 05:44 PM
JesseR
Mountain City, TN
Sounds like I get to save a $1000 or so and keep what I have since this is a nitrous only deal. Thank you all for the input
[Re: JesseR]
#1970473
12/15/15 10:34 PM
12/15/15 10:34 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Take the carb you have and tune it properly for the engine to run as good as it possibly can on MOTOR.........do this, then turn the spray on and forget it. No matter how much nitrous you spray, the CARB will NEVER need to pass more air than the motor does while in N/A trim. The more nitrous you spray, the more it displaces air from the intake and N/A power goes down, because carb is drawing less air and fuel.
[Re: Monte_Smith]
#1970558
12/16/15 12:02 AM
12/16/15 12:02 AM
JesseR
Mountain City, TN
Thanks monte, we've done exactly that. I ran it just enough times to get the motor happy and then sprayed it and have not looked back. I'm glad I posted this because I was unaware about all the blade size and stuff effecting my tuneup and the difference the nitrous makes to the actual airflow
