440 build #1966488
12/09/15 07:44 PM
12/09/15 07:44 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Starting to think about my 440 build, going to start this winter. Anyone have experience with Howard Cams?. It's not a wild build, I'm looking at one of their hydraulic roller cam and lifter sets. A little more spendy than normal stuff but I like the efficiency/extra power of the roller set up. Anyone use them?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 440 build [Re: busboy] #1967037
12/10/15 01:44 PM
12/10/15 01:44 PM
dogdays Offline
dogdays  Offline
I don't have anything from Howard's but they are a very reputable company and have been around forever. I wouldn't hesitate to buy something from them.
DO prepare yourself for the inevitable flood of replies telling you the hydraulic roller won't gain you anything and use a flat-tappet cam.
IMHO if you have the resources and are not looking for the last tenth of a second then go for it. There is friction between cam lobe and lifter. A few years ago while adjusting the valves on my Poly 318 I discovered that I could slow down the engine by pushing down hard on the pushrod end of the rocker. There's a reason that most OEM lifters these days are hydraulic roller. They cost more so they must make something better.
Also the relief of not having to break in a cam or to swap lifters from one cam to the next without worry is substantial.
R.
Re: 440 build [Re: dogdays] #1967054
12/10/15 02:06 PM
12/10/15 02:06 PM
^ that^
Re: 440 build [Re: busboy] #1967274
12/10/15 07:13 PM
12/10/15 07:13 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'm one of the flat tappet guys but it's not worth arguing about if I'm not building it...lol.
Howards is good stuff. But if it were me I'd use their lifters and a different cam manufacturer. Just personal preference on the cam but Howards makes a damn fine hydraulic roller lifter. If you're going to run one - good choice on the lifters.
Re: 440 build [Re: moper] #1967314
12/10/15 08:19 PM
12/10/15 08:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'll let you know within the month.
I had a flat tappet .557 MP cam with Comp lifters in my 505.
Despite using ZDDP oil, comp breakin lube, making sure the lifters rotated in the bores easily, prelubing the engine before startup and doing the "keep it above 2500 rpm for 15 minutes" I ended up wiping 9 lobes!
It didn't happen right away, either. Had over 80 miles on the motor before it started to happen.
I've run the .528 MP flat tappet for over 10,000 miles and never had a single issue so I'm not sure what happened other than inferior (soft) materials in the cam or lifters.
Consequently, I'm rebuilding it with a Howards hydraulic roller. Lifters are already here but cam is on backorder. It's supposed to be here by the 18th of December.
I was always a hard core flat tappet guy but not after this!
Re: 440 build [Re: busboy] #1967759
12/11/15 03:06 PM
12/11/15 03:06 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Weird. First impressions are a lifter bore issue. I can't see an MP grind eating 9 lobes unless there's a wear or angle issue with the block itself.
Re: 440 build [Re: busboy] #1967815
12/11/15 04:28 PM
12/11/15 04:28 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I dunno. I lost 2 hydraulic cams this year. One was a comp cams under .500 lift 23 runs and 300 street miles and one MP mild cam that came in the 383 I bought some years ago. Basically street miles (no idea how many but I am sure not too much). I had been running Valvoline racing oil but will try something else. I am giving Com Cams another try in 2 applications (383 street engines).
Re: 440 build [Re: moper] #1968130
12/12/15 01:10 AM
12/12/15 01:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Honestly, I think the Comp lifters were the issue. Once they started to go then the cam's lobes went away.
Re: 440 build [Re: busboy] #1968159
12/12/15 01:32 AM
12/12/15 01:32 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Curious - which ones (as in cylinder/position) went bad?
Re: 440 build [Re: moper] #1968162
12/12/15 01:38 AM
12/12/15 01:38 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Double springs?
Pressure over the nose?
EDM lifters?
Re: 440 build [Re: moper] #1968177
12/12/15 02:16 AM
12/12/15 02:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Pretty random. Some cylinders both, some intake, some exhaust.
Re: 440 build [Re: 64Post] #1968180
12/12/15 02:19 AM
12/12/15 02:19 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By 64Post
Double springs?
EDM lifters?
Single springs.
Not sure, I'd have to look at paperwork but they were used successfully in the previous 440 with an MP .484 Hydraulic camwith no issues..
Not EDM lifters. Just solid flat tappet Comps.
Re: 440 build [Re: GY3] #1968195
12/12/15 03:01 AM
12/12/15 03:01 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Double springs?
EDM lifters?
Single springs.
Fecal lifters or cam
Re: 440 build [Re: 64Post] #1968228
12/12/15 06:01 AM
12/12/15 06:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Funny as I have never run a roller and I have never wiped a cam lobe on any of my flat tappet cams. The present eng in my 63 I built and installed in my 63 in June 2011. I use EDM lifters and took the inner springs out for cam break in. Its a custom grind from Dwayne Porter thats .585 & .592 lift with 264 & 270 @ .050 and it has a 110 LSA. I have it in my eng on a 106 ICL and the cam was Nitrided. I use and have always used Valvoline VR-1 racing oil and I added a bottle of Zinc additive. My 493 is still going strong after 4 years and many street miles and a few passes down the 1/4 mile. Ron
Re: 440 build [Re: busboy] #1968497
12/12/15 06:00 PM
12/12/15 06:00 PM
busboy Offline OP
busboy  Offline OP
Thanks for the reply's, sounds like a descent outfit. Mines a pretty stock build, balanced rotating assembly, a little clean up got it to .40 over, eddy 84cc heads and eventually a six pack all going into a 3800lb B body four speed street car. So far I'm leaning towards one of the Rattler cam and lifter kits CL728045-09, says it's 235/243 @.050", .530 lift on 109LSA designed for 2000-5600 rpm.
Re: 440 build [Re: busboy] #1968781
12/13/15 03:04 AM
12/13/15 03:04 AM
for a regular cam do all of the caveats: correct spring psi for breakin. zinc oil. proper prep so it stats INSTANTLY. conservative timing for breakin. Hughes lifter OD clearance precheck "the thunk test". thermostat OUT. load the eng (I hear a dyno is the best??). cooling fan in front of rad. mixture not too rich. read "breakin secrets" at www.mototuneusa.com which is more for rings but applies to cams also. front of car jacked up (helps with air pockets) & gives room underneath to spot any leaks/issues. ANY issue dont think about it just shut it off now/fix it/then restart & continue on on the breakin time. you in dr seat to goose the throttle and shout orders! several helpers, one to set dist to total (36). another guy to add trans fluid another guy to check for leaks. You have thousands of $$$ & alot of time in this & you have ONE shot to get an excellent breakin as opposed to a mediocre breakin that has lower leakdown numbers & wears out sooner on down the line years from now. You have ONE shot!
Re: 440 build [Re: RapidRobert] #1968808
12/13/15 05:11 AM
12/13/15 05:11 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Did all of this. Still had issues as have others.
Do some searches on Comp Cams and you'll find their quality is not what it once was. The help they have there are idiots as well. They spec'd me a .480 lift, 280 adv. duration for my 505" stroker with ported heads! shruggy
When I asked if they were sure about this recommendation they said "Yep!".
Re: 440 build [Re: GY3] #1969120
12/13/15 08:38 PM
12/13/15 08:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree as why would anyone spec a cam like that for a 505 stroker ?? confused realcrazy Heck I had more cam then that in my stock 383 with pocket ported 452 heads. Ron
Re: 440 build [Re: GY3] #1969327
12/14/15 03:28 AM
12/14/15 03:28 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
That's why I spec my own cams.
Re: 440 build [Re: busboy] #1969350
12/14/15 08:33 AM
12/14/15 08:33 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
All this was primary reason put a roller in my 512 the last time apart,,, and also not to again burn the ceramic coating off my TTI headers doing a cam breakin. Had cost me over 300 bucks to recoat them from a prior cam breakin,,,figured that saving would pay the diff from a flat tappet cam. Of course however a few hundred miles later had to deal with a collapsed Scorpion lifter on number 6 exhaust.
