indy & eddy intake offset #196818
01/18/09 01:01 AM
01/18/09 01:01 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
is the rocker offset for 440-1s & eddy victors the same.if not what's the diff.
Re: indy & eddy intake offset [Re: 72sat] #196819
01/18/09 02:41 AM
01/18/09 02:41 AM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
The offsets are not the same. Indy offsets its intake rockers .850 for the 440-1 heads. T&D Machine offsets its intake rockers .725 for the Eddy Victor heads. I believe the Indy rockers can be used on the Victors but the T&D Victor rockers can't be used on the 440-1 heads. T&D makes another rocker specifically for the 440-1 heads.
Re: indy & eddy intake offset [Re: 72sat] #196820
01/18/09 01:17 PM
01/18/09 01:17 PM
AndyF Offline
AndyF  Offline
Some people have used the 440-1 rocker arms on the Victor heads so it must work okay. It might only work on an RB block though as the pushrod angle might be too steep on a B block.
On my MW Victor's it looked to me like a .750 offset on the intakes would be best. Or maybe a .650 offset with an offset pushrod cup in the lifter would also work.
The 440-1 offset is .850 and that would also work on my Victor heads but the pushrod hole in the head would need to enlarged since the pushrod would be pushed over a fair amount.
