Re: Simple 727 mods?
[Re: MadMez]
#1967732
12/11/15 02:31 PM
12/11/15 02:31 PM
Posts: 3,922 Richmond, Indiana
19swinger70
Richmond, Indiana
I'd say at minimum:
New filter (3 screws to remove - easy)
Check the band adjustment - easy
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: MadMez]
#1967756
12/11/15 02:58 PM
12/11/15 02:58 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The pressure releif spring has lost some tension over the last almost 50 years so a couple turns out on it is good. Check both band adjustments with the pan off. Re-fill with type-f fluid. Other than that a 727 is really overkill for a mild 383 and no mods would do much for performance.
[Re: HotRodDave]
#1967833
12/11/15 05:21 PM
12/11/15 05:21 PM
RapidRobert
set the gap under the two levers just like you would valve lash. kunkel has me set my circle track 904 to 1/4 and 5/16 (I forgot which band was which/dont have the note in front of me right now). As said you might want to adj the hex screw (see what the guys say). new filter new gasket pan rails straight especially the perimeter around the pan holes. Any screws going into aluminum its a good plan to lube em but they should be wet with trans fluid as is but I'd check. I'd use some non hardening gasket cement (permatex #2) on the pan bolts to help keep em snug (not a dealbreaker but one of my idiosynchrosies (sp)
[Re: BigBlockMopar]
#1968062
12/11/15 11:46 PM
12/11/15 11:46 PM
RapidRobert
You could decide to replace the throttle pressure shaft, gear-selector shaft and oilfillertube seals. X2, VG plan (perfect time to do it) EDIT IF you are comfortable with taking out the VB which is the best way to access the big seal
[Re: MadMez]
#1970889
12/16/15 04:28 PM
12/16/15 04:28 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
How about a pan drain plug and check the pan mounting bolt threads in the tranny case. I had some that were stripped so I opted to have them fixed with heli-coils.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Rob C]
#1988536
01/11/16 04:04 PM
01/11/16 04:04 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The MP is the absolute worst choice for a "kit", nothing there that you can't duplicate for free and minimal improvement.
