grand cherokee rear drivers side door #1966846
12/10/15 03:18 AM
12/10/15 03:18 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
it wont open from the inside or outside handles,door lock is in off position,can i kick it open from the inside?,doubt i can get the panel off with it closed,dont think it has child proof locks as its a 93 model,any ideas
thanks!
my ladder of success is missing some rungs
Re: grand cherokee rear drivers side door [Re: rhad] #1967056
12/10/15 02:07 PM
12/10/15 02:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried soaking the latch with PB Blaster? How about lifting up on the door while trying to open it. Sometimes those things work.
Re: grand cherokee rear drivers side door [Re: rhad] #1967309
12/10/15 08:08 PM
12/10/15 08:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If its dragging on the body, or the latch is stiff, giving it a swift semi hard kick might open it. Once you get it open, figure out what caused the problem and fix it before to slam it closed. You might not get another chance.
Those Jeeps are really good at wearing out the pin on the door hinges, which lets the door sag, after a while, it either breaks the hing, tears the hing away from the body, rips the stud out of the door post or mangles the latch from beating it against the stud. Usually, just before it ceases function, it will bind up once or twice. I've fixed all 4 issues, any one, or any combination of them, (including all 4 on the same door!) many times over the last several years.
My bet is, once the door opens, its going to drop a couple inches once it clears the latch. Gene
Re: grand cherokee rear drivers side door [Re: poorboy] #1967578
12/11/15 04:07 AM
12/11/15 04:07 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i got it open,slid the inside lock back and forth a few times and it opened with the inside latch
thanks everyone!!
