440 build
#1966488
12/09/15 07:44 PM
12/09/15 07:44 PM
Posts: 670 Third rock from the sun.
busboy
Starting to think about my 440 build, going to start this winter. Anyone have experience with Howard Cams?. It's not a wild build, I'm looking at one of their hydraulic roller cam and lifter sets. A little more spendy than normal stuff but I like the efficiency/extra power of the roller set up. Anyone use them?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 440 build
[Re: dogdays]
#1967054
12/10/15 02:06 PM
12/10/15 02:06 PM
RapidRobert
Also the relief of not having to break in a cam or to swap lifters from one cam to the next without worry is substantial. ^ that^
Re: 440 build
[Re: busboy]
#1967274
12/10/15 07:13 PM
12/10/15 07:13 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'm one of the flat tappet guys but it's not worth arguing about if I'm not building it...lol. Howards is good stuff. But if it were me I'd use their lifters and a different cam manufacturer. Just personal preference on the cam but Howards makes a damn fine hydraulic roller lifter. If you're going to run one - good choice on the lifters.
Re: 440 build
[Re: busboy]
#1967759
12/11/15 03:06 PM
12/11/15 03:06 PM
moper
Columbia, CT
Weird. First impressions are a lifter bore issue. I can't see an MP grind eating 9 lobes unless there's a wear or angle issue with the block itself.
Re: 440 build
[Re: busboy]
#1967815
12/11/15 04:28 PM
12/11/15 04:28 PM
Posts: 4,276 Morrow, OH
markz528
Morrow, OH
I dunno. I lost 2 hydraulic cams this year. One was a comp cams under .500 lift 23 runs and 300 street miles and one MP mild cam that came in the 383 I bought some years ago. Basically street miles (no idea how many but I am sure not too much). I had been running Valvoline racing oil but will try something else. I am giving Com Cams another try in 2 applications (383 street engines).
Re: 440 build
[Re: moper]
#1968130
12/12/15 01:10 AM
12/12/15 01:10 AM
Posts: 4,693 Wichita
GY3
Wichita
Weird. First impressions are a lifter bore issue. I can't see an MP grind eating 9 lobes unless there's a wear or angle issue with the block itself. Honestly, I think the Comp lifters were the issue. Once they started to go then the cam's lobes went away.
Re: 440 build
[Re: busboy]
#1968159
12/12/15 01:32 AM
12/12/15 01:32 AM
moper
Columbia, CT
Curious - which ones (as in cylinder/position) went bad?
Re: 440 build
[Re: moper]
#1968162
12/12/15 01:38 AM
12/12/15 01:38 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Double springs?
Pressure over the nose?
EDM lifters?
Re: 440 build
[Re: moper]
#1968177
12/12/15 02:16 AM
12/12/15 02:16 AM
GY3
Wichita
Curious - which ones (as in cylinder/position) went bad? Pretty random. Some cylinders both, some intake, some exhaust.
Re: 440 build
[Re: 64Post]
#1968180
12/12/15 02:19 AM
12/12/15 02:19 AM
GY3
Wichita
Double springs?
EDM lifters? Single springs. Not sure, I'd have to look at paperwork but they were used successfully in the previous 440 with an MP .484 Hydraulic camwith no issues.. Not EDM lifters. Just solid flat tappet Comps.
Re: 440 build
[Re: GY3]
#1968195
12/12/15 03:01 AM
12/12/15 03:01 AM
64Post
Baltimore/Denver
Double springs?
EDM lifters? Single springs. Not sure, I'd have to look at paperwork but they were used successfully in the previous 440 with an MP .484 Hydraulic camwith no issues.. Not EDM lifters. Just solid flat tappet Comps. Fecal lifters or cam
Re: 440 build
[Re: 64Post]
#1968228
12/12/15 06:01 AM
12/12/15 06:01 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Funny as I have never run a roller and I have never wiped a cam lobe on any of my flat tappet cams. The present eng in my 63 I built and installed in my 63 in June 2011. I use EDM lifters and took the inner springs out for cam break in. Its a custom grind from Dwayne Porter thats .585 & .592 lift with 264 & 270 @ .050 and it has a 110 LSA. I have it in my eng on a 106 ICL and the cam was Nitrided. I use and have always used Valvoline VR-1 racing oil and I added a bottle of Zinc additive. My 493 is still going strong after 4 years and many street miles and a few passes down the 1/4 mile. Ron
Re: 440 build
[Re: busboy]
#1968497
12/12/15 06:00 PM
12/12/15 06:00 PM
busboy
Thanks for the reply's, sounds like a descent outfit. Mines a pretty stock build, balanced rotating assembly, a little clean up got it to .40 over, eddy 84cc heads and eventually a six pack all going into a 3800lb B body four speed street car. So far I'm leaning towards one of the Rattler cam and lifter kits CL728045-09, says it's 235/243 @.050", .530 lift on 109LSA designed for 2000-5600 rpm.
Re: 440 build
[Re: busboy]
#1968781
12/13/15 03:04 AM
12/13/15 03:04 AM
RapidRobert
for a regular cam do all of the caveats: correct spring psi for breakin. zinc oil. proper prep so it stats INSTANTLY. conservative timing for breakin. Hughes lifter OD clearance precheck "the thunk test". thermostat OUT. load the eng (I hear a dyno is the best??). cooling fan in front of rad. mixture not too rich. read "breakin secrets" at www.mototuneusa.com which is more for rings but applies to cams also. front of car jacked up (helps with air pockets) & gives room underneath to spot any leaks/issues. ANY issue dont think about it just shut it off now/fix it/then restart & continue on on the breakin time. you in dr seat to goose the throttle and shout orders! several helpers, one to set dist to total (36). another guy to add trans fluid another guy to check for leaks. You have thousands of $$$ & alot of time in this & you have ONE shot to get an excellent breakin as opposed to a mediocre breakin that has lower leakdown numbers & wears out sooner on down the line years from now. You have ONE shot!
Re: 440 build
[Re: RapidRobert]
#1968808
12/13/15 05:11 AM
12/13/15 05:11 AM
GY3
Wichita
for a regular cam do all of the caveats: correct spring psi for breakin. zinc oil. proper prep so it stats INSTANTLY. conservative timing for breakin. Hughes lifter OD clearance precheck "the thunk test". thermostat OUT. load the eng (I hear a dyno is the best??). cooling fan in front of rad. mixture not too rich. read "breakin secrets" at www.mototuneusa.com which is more for rings but applies to cams also. front of car jacked up (helps with air pockets) & gives room underneath to spot any leaks/issues. ANY issue dont think about it just shut it off now/fix it/then restart & continue on on the breakin time. you in dr seat to goose the throttle and shout orders! several helpers, one to set dist to total (36). another guy to add trans fluid another guy to check for leaks. You have thousands of $$$ & alot of time in this & you have ONE shot to get an excellent breakin as opposed to a mediocre breakin that has lower leakdown numbers & wears out sooner on down the line years from now. You have ONE shot! Did all of this. Still had issues as have others. Do some searches on Comp Cams and you'll find their quality is not what it once was. The help they have there are idiots as well. They spec'd me a .480 lift, 280 adv. duration for my 505" stroker with ported heads! When I asked if they were sure about this recommendation they said "Yep!".
Re: 440 build
[Re: GY3]
#1969120
12/13/15 08:38 PM
12/13/15 08:38 PM
383man
Balt. Md
for a regular cam do all of the caveats: correct spring psi for breakin. zinc oil. proper prep so it stats INSTANTLY. conservative timing for breakin. Hughes lifter OD clearance precheck "the thunk test". thermostat OUT. load the eng (I hear a dyno is the best??). cooling fan in front of rad. mixture not too rich. read "breakin secrets" at www.mototuneusa.com which is more for rings but applies to cams also. front of car jacked up (helps with air pockets) & gives room underneath to spot any leaks/issues. ANY issue dont think about it just shut it off now/fix it/then restart & continue on on the breakin time. you in dr seat to goose the throttle and shout orders! several helpers, one to set dist to total (36). another guy to add trans fluid another guy to check for leaks. You have thousands of $$$ & alot of time in this & you have ONE shot to get an excellent breakin as opposed to a mediocre breakin that has lower leakdown numbers & wears out sooner on down the line years from now. You have ONE shot! Did all of this. Still had issues as have others. Do some searches on Comp Cams and you'll find their quality is not what it once was. The help they have there are idiots as well. They spec'd me a .480 lift, 280 adv. duration for my 505" stroker with ported heads! When I asked if they were sure about this recommendation they said "Yep!". I agree as why would anyone spec a cam like that for a 505 stroker ?? Heck I had more cam then that in my stock 383 with pocket ported 452 heads. Ron
Re: 440 build
[Re: GY3]
#1969327
12/14/15 03:28 AM
12/14/15 03:28 AM
64Post
Baltimore/Denver
for a regular cam do all of the caveats: correct spring psi for breakin. zinc oil. proper prep so it stats INSTANTLY. conservative timing for breakin. Hughes lifter OD clearance precheck "the thunk test". thermostat OUT. load the eng (I hear a dyno is the best??). cooling fan in front of rad. mixture not too rich. read "breakin secrets" at www.mototuneusa.com which is more for rings but applies to cams also. front of car jacked up (helps with air pockets) & gives room underneath to spot any leaks/issues. ANY issue dont think about it just shut it off now/fix it/then restart & continue on on the breakin time. you in dr seat to goose the throttle and shout orders! several helpers, one to set dist to total (36). another guy to add trans fluid another guy to check for leaks. You have thousands of $$$ & alot of time in this & you have ONE shot to get an excellent breakin as opposed to a mediocre breakin that has lower leakdown numbers & wears out sooner on down the line years from now. You have ONE shot! Did all of this. Still had issues as have others. Do some searches on Comp Cams and you'll find their quality is not what it once was. The help they have there are idiots as well. They spec'd me a .480 lift, 280 adv. duration for my 505" stroker with ported heads! When I asked if they were sure about this recommendation they said "Yep!". That's why I spec my own cams.
Re: 440 build
[Re: Sxrxrnr]
#1969488
12/14/15 03:38 PM
12/14/15 03:38 PM
64Post
Baltimore/Denver
All this was primary reason put a roller in my 512 the last time apart,,, and also not to again burn the ceramic coating off my TTI headers doing a cam breakin. Had cost me over 300 bucks to recoat them from a prior cam breakin,,,figured that saving would pay the diff from a flat tappet cam. Of course however a few hundred miles later had to deal with a collapsed Scorpion lifter on number 6 exhaust. TTI warns users to NOT break in a new build/cam with their headers installed.
Re: 440 build
[Re: busboy]
#1969490
12/14/15 03:39 PM
12/14/15 03:39 PM
moper
Columbia, CT
Did you actually measure the bores and lifters to get lifter-to-bore clearance? There is much more potential for a problem either with the lifter bore machining in the block or with lifter bore wear, then with a production problem with a specific brand of lifter or camshaft. The problem becomes the angle that the lifter hits the face of the lobe is allowed to deviate some. It doesn't take much to have it be wrong, and to have a failure. Think about how (cough...cough...) accurate the rest of the block machining from the factory was. I think you have a block that has some wear, and possible angle issues with the lifter bores. It's not uncommon at all but ask around and see how many shops/builders check for clearance (I do) or bore accuracy (I typically won't unless there's a history to warrant it) during the block machining phase. In most cases the care and process will allow things to work fine over a long service life. in other cases they may have one or some that are so bad it only takes a minor increase in cam size and required spring pressures before a problem surfaces. Things such as too little or too much preload, loss of valve train control due to improperly set valve spring heights, and weak pushrods can also cause cams to give up.
Re: 440 build
[Re: dogdays]
#1969495
12/14/15 03:44 PM
12/14/15 03:44 PM
64Post
Baltimore/Denver
Guys, remember that Comp outsources their lifters and camshaft cores just like everyone else. So saying that Comp cams or lifters are crap just because they're Comp indicates your ignorance.
Or maybe I should tell you how I really feel.........
R. Eddie Miller told me several years ago that Comp gets its cores from the only two places that supply them. If you bought a shelf grind, the cores came from one budget vendor. If you spec'd a custom grind, the cores came from a different/better vendor. IIRC, he said Crane was the better supplier.
