70 a100 questions #1965944
12/08/15 10:59 PM
12/08/15 10:59 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
i'm having trouble finding front rearward leaf spring bushings for the shackle end on the ol 70 a100... any part numbers?
also put a 4 barrel eddy on it but having issue with the stock pedal linkage, either it holds the throttle open too much at idle or it doesn't dip into those nice big secondaries... any recommended linkage additions or mods?
on a side note the intermediate oil pump dizzy shaft is a little sloppy looks to have some wear on the gear and the oil pump shaft side... was thinking the bushing and shaft might need replacing?
any help is great, thanks smile
https://www.facebook.com/photo.php?fbid=...e=3&theater
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: 70 a100 questions [Re: maxi333] #1966091
12/09/15 02:20 AM
12/09/15 02:20 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You have any 4x4 shops in your area? Our local guy stocks drawers full of rubber bushings, you just have to know the ID and the OD of the bushings. I also wouldn't put it past such things being at Rock Auto.
On the carb, I believe there is a linkage adapter you have to buy for the Eddy on a Mopar intake.
The oil pump intermediate shaft only has to turn the oil pump. As long as the slop isn't causing variation in the ign timing, I wouldn't be concerned about the oil pump drive. If the slop is effecting the timing, a new one would already be in there. Gene
