Small Block cooling and oil pressure #196551
01/17/09 09:51 PM
01/17/09 09:51 PM
Central Florida, Tampa area
rallyerick Offline OP
I thought that I may have seen a similar question before, but could not find it.
I have 74 Dart that I recently bought. Previous owner claims the engine, a 360, to be "Rebuilt". Here's the problem:
When it is first started, oil pressure is about 50-lbs. As it warms-up, the oil pressure begins to drop as the temperature rises. By about 180-degs, the oil pressure has hit zero. Compression is good, as is vacuum and there is no blow-by.
Any suggestions?
THANKS
Re: Small Block cooling and oil pressure [Re: rallyerick] #196552
01/17/09 10:19 PM
01/17/09 10:19 PM
Zero psi is never good, my first thoughts are is the engine noisy and are you sure you have a properly working gauge.
Re: Small Block cooling and oil pressure #196553
01/17/09 10:31 PM
01/17/09 10:31 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If indeed you have 0 pressure and hydraulic lifters they would be rattling to beat the band. They will be the first thing to make noise.
Re: Small Block cooling and oil pressure [Re: rallyerick] #196554
01/17/09 10:43 PM
01/17/09 10:43 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
If you're lucky the oil pressure relief valve in the oil pump is stuck in the open position or someone forgot to replace the 9/16 cup plug in the oil passage that separates oil going to the filter from oil leaving it when the engine was rebuilt. You can check the plug by removing the oil pressure sending unit and sticking a coat hanger wire down the hole. The wire should bottom out between 71/2 in.-711/16in. from the deck if the plug was installed correctly. If the plug is missing, you will have to pull the pan, oil pump and rear main to replace it. If its the pump, the rear main stays in place. If its not one of these I think you may have a real problem. Good luck and let us know what you find.
Re: Small Block cooling and oil pressure [Re: rallyerick] #196555
01/17/09 11:11 PM
01/17/09 11:11 PM
I'd R&R the pan & throw on a new oil pump EDIT but do open it up & clean it w solvent/check clearances & oil it & dont use a gasket between the oil pump & main cap even if one is included.
Re: Small Block cooling and oil pressure [Re: RapidRobert] #196556
01/17/09 11:41 PM
01/17/09 11:41 PM
Thanks for the replies!!!
Noise: When the pressure is about to bottom out, it almost sounds like a light rod knocking.
Guage: It is a fairly new Sun-Pro mechanical guage, I'm assuming it is working properly.
I'll try the coat hanger test tomorrow ater I do the brakes on my In-laws T&C Van.
Thanks again!!!
Re: Small Block cooling and oil pressure [Re: rallyerick] #196557
01/18/09 10:01 AM
01/18/09 10:01 AM
Upper Midwest
Upper Midwest
Likely is.
Lifters should be rattling very loudly too though. Like I said they are will rattle very early when the oil pressure drops. It takes oil pressure to keep them filled.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
