2007 dodge charger updated timeslip #196530
01/17/09 09:19 PM
01/17/09 09:19 PM
houston texas
gremlinsteve Offline OP
houston texas
took the green bomber back to the track this weekend (last night) as the season just opened up again for us.
good weather with a very so-so track prep. humidity was in the 70 percent range also so i am sure that contributed.
short times where not spot on as they had been. close, but lacking about half a tenth from the last outing.
tag that along with the dumb dumb in the 150k porche 911 all wheel drive twin turbo carrera who drove it off the end of the track because he did not know where to turn and the ensuing 2 hours delay and you have a recipe for a long wait.
here is the car, same pic as before. do not have any new ones loaded up yet and the car has not changed.
car managed to pull off a 1.66 short time and hit 115.95 mph with a 11.72 et. not bad for a heavy heavy car....tore up the axle hub on the last pass. we are definetly taxing the suspension on this car. it is still 4 wheel independent running a 2.82 rear gear.
drag radial is the same from last season.
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196531
01/17/09 09:22 PM
01/17/09 09:22 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Your car looks mean!!
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196532
01/17/09 10:32 PM
01/17/09 10:32 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Cool!
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196533
01/17/09 11:00 PM
01/17/09 11:00 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
That's impressive!
That much weight with that rear gear
Tell me about the car. Engine? Power adders?
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: 2007 dodge charger updated timeslip [Re: fasteddie] #196534
01/18/09 12:18 AM
01/18/09 12:18 AM
houston texas
houston texas
all motor.
5.7 based 392 stroker
kit was by callies/compstar
basic build. mild camshaft
2800 converter
long tubes..
a few minor bolts ons other than that
steve
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196535
01/18/09 10:39 PM
01/18/09 10:39 PM
houston texas
houston texas
the time slip
steve
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196536
01/18/09 10:41 PM
01/18/09 10:41 PM
houston texas
houston texas
pics of the car
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196537
01/18/09 10:42 PM
01/18/09 10:42 PM
houston texas
houston texas
another in the series
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196538
01/18/09 10:43 PM
01/18/09 10:43 PM
houston texas
houston texas
one more
Re: 2007 dodge charger updated timeslip [Re: gremlinsteve] #196539
01/18/09 10:45 PM
01/18/09 10:45 PM
houston texas
houston texas
another
