Big Block Motor Mount Brackets How they Mount To Motor #1965170
12/07/15 10:41 PM
12/07/15 10:41 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I have a 72 Challenger that I am dropping a "B" block in.
I got the car without a motor so I can't refer to that.
It was a small block car so it has the V8 K member.
I bought the mounts and mounting brackets.
Do the brackets bolt behind the ears or in front on the motor?
I did a search and found where a B body they are mounted behind.
I just want to verify for the E body.
Thanks in advance for your help.
Re: Big Block Motor Mount Brackets How they Mount To Motor [Re: patosmith] #1965268
12/08/15 12:19 AM
12/08/15 12:19 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you'll find they only go one way. One of the block ears is thicker so if you try to put the mount on incorrectly you'd notice you'd need a big spacer for the other ear.
Re: Big Block Motor Mount Brackets How they Mount To Motor [Re: patosmith] #1965302
12/08/15 12:54 AM
12/08/15 12:54 AM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: Big Block Motor Mount Brackets How they Mount To Motor [Re: 71DemonRON] #1965495
12/08/15 12:16 PM
12/08/15 12:16 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
bracket with tube in middle goes on drivers side,behind ears. long bolt goes in the tube.
bracket that is open goes on passenger side on rear of ears.
its so simple even a caveman can do it!
Re: Big Block Motor Mount Brackets How they Mount To Motor [Re: Joesixpack] #1965507
12/08/15 12:40 PM
12/08/15 12:40 PM
P
P
Thanks everyone!
Just wanted to make sure.
Stanton, you're right, one is thicker so the bracket could not go on in front of the ear.
Re: Big Block Motor Mount Brackets How they Mount To Motor [Re: patosmith] #1965640
12/08/15 04:09 PM
12/08/15 04:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By patosmith
Thanks everyone!
If you have the correct brackets they only go on one way
