69 Charger RT brake problem........... #196502
01/17/09 08:55 PM
01/17/09 08:55 PM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
Need some advice. I was driving down a hill pressed the brake pedal down and it stayed down. Replaced the booster last year so I thought it was the master cylinder, it's 15+ years old. Bench bled and installed new master cylinder. However it won't build up pressure? I opened the bleeder on the passenger caliber and fluid barely comes out. Pedal still "Dangles", no pressure at all just goes to the floor. I see two proportional valves along the frame that the hard lines from the Master cylinder go into. Could they both or one of them be bad? Thanks! TC
Re: 69 Charger RT brake problem........... [Re: tcs69rt] #196503
01/17/09 09:27 PM
01/17/09 09:27 PM
My first thought would be a bad MC. You might split the MC & booster & see if there's some free play in the threaded rod. I plug both MC ports with (2) brass plugs & if the MC/booster are good it'll have a rock hard pedal with virtually no travel(with eng idling if power).
Re: 69 Charger RT brake problem........... [Re: RapidRobert] #196504
01/18/09 02:20 AM
01/18/09 02:20 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I would agree with the master cylinder, there is a big spring inside the master cylinder that is supposed to push the rod back.
The spring could be bad, or the piston in the master cylinder could be rusted..
