4bb shaker base identification #1964451
12/06/15 05:21 PM
12/06/15 05:21 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
Can someone tell me if this is an org base
Re: 4bb shaker base identification [Re: westfort] #1964476
12/06/15 06:08 PM
12/06/15 06:08 PM
MD
floyd Offline
floyd  Offline
MD
Original 340 baseplate. You need to measure the throat height to tell if it is a 70 or 71 340 base.
4-Barrel Shaker Bases
Engine--Part#--Throat Depth*
1970 340--3512765--1 ¾”
1971 340--3512764--1 ½”
383--3462485--2”
440-4--3462484--1 ½”
* Measured from bottom the carb stud bridge to the bottom of throat base.
Re: 4bb shaker base identification [Re: westfort] #1964490
12/06/15 07:01 PM
12/06/15 07:01 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
Thanks I do see a lot of that part num on it for 70 thanks
