318 Crank??? #196342
01/17/09 06:49 PM
01/17/09 06:49 PM
Anonymous OP
Anonymous OP
Is there any way to tell by looking at a 318 crank if it's cast or forged. Because a 340 and 318 have the same crank correct. Thanks
Re: 318 Crank??? #196343
01/17/09 08:09 PM
01/17/09 08:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not hardly.
340 and 318 might share the same main bearing size and stroke, but the cranks are not the same.
As for the original question, yes there is a way to tell the difference by looking.
Don't be the exception.
Re: 318 Crank??? [Re: Supercuda] #196344
01/17/09 08:37 PM
01/17/09 08:37 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Steel cranks have bigger parting lines where they are forged together. Cast have small ones and have casting clocks and some numbers cast into them. A steel 318 (and 273) crank does not have a hole through the rod journal end and a 340 does have a hole. The 273 and the 318 steel are the same crank. They get the right balance by using a real heavy piston pin in the 273.
Re: 318 Crank??? [Re: fastmark] #196345
01/17/09 09:35 PM
01/17/09 09:35 PM
What is different on the 273 that it needs the heavy piston pin to balance out?
Re: 318 Crank??? [Re: RapidRobert] #196346
01/17/09 09:43 PM
01/17/09 09:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
There have been many 318 shafts used in 340's. Many without rebalancing and gotten away with it, but they SHOULD be rebalanced for 340 use to be right.
Re: 318 Crank??? [Re: MoparforLife] #196347
01/17/09 11:43 PM
01/17/09 11:43 PM
I am building a 273(from scratch) & I'm wondering if there's a balance issue that is going to bite me in the tail later. I have a 318 crank/rods that I can use(dont know what year though, might be 80's). When you mentioned "extra heavy pin" that worried me
Re: 318 Crank??? #196348
01/18/09 12:01 AM
01/18/09 12:01 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
where are you located? Is a steel crank absolutely necessary in your build? I have 2 fresh, cast 318 cranks here.
Re: 318 Crank??? [Re: fastmark] #196349
01/18/09 12:20 AM
01/18/09 12:20 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Poly 318 engines used steel cranks with no holes in the rod journals. Crank is a pretty stout piece.
Re: 318 Crank??? [Re: RapidRobert] #196350
01/19/09 09:33 AM
01/19/09 09:33 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
uh, the pistons are much smaller in diameter, so they're lighter....
btw, somewhere in the early to mid 70's, they started using they commonized rods and started using the 340/360 rods in 318's, so an 80's 318 will have heavier rods than a 273/late 60's 318
2017 Grand Cherokee Overland
Re: 318 Crank??? [Re: patrick] #196351
01/19/09 11:53 AM
01/19/09 11:53 AM
Alright so they just used a heavier pin so they wouldn't have to rebalance that particular combination. I got it. It didn't make sense at first because using a heavier anything is the oppposite of what we normally want to do especially a pin because they dont break & you certainly wouldn't want to add to the reciprocating weight . thank you Patrick.
Re: 318 Crank??? [Re: RapidRobert] #196352
01/19/09 10:10 PM
01/19/09 10:10 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Sorry I did not check back but the reason is the lighter pistons. You ought to see the pin. It looks like it may have a .250 hole in the middle. It is heavy.
Re: 318 Crank??? [Re: fastmark] #196353
01/20/09 12:58 AM
01/20/09 12:58 AM
Fastmark Since I would be rebalancing can a person use another SB pin(like a 318 one for instance) in these 273 pistons?
Re: 318 Crank??? [Re: RapidRobert] #196354
01/20/09 01:56 AM
01/20/09 01:56 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I am not Fast mark but yes it would be a good idea
