No Heat in my 94 Dodge Ram #196329
01/17/09 06:28 PM
01/17/09 06:28 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
engine gets plenty hot, about 200 deg. Blower motor works well. The heater hoses are very hot all the way up to the firewall. I assume this is the heater core? Is there anyway to flush this thing? I don't want to pull the dash, I did a few years ago, when the evaporator started to leak. Is there any flush chemicals, and compressed air would uncork this thing, if it is actually plugged up. I disconnected the A/C unit, to make sure it wasn't fighting each other.
Re: No Heat in my 94 Dodge Ram [Re: Bob_Coomer] #196330
01/17/09 06:49 PM
01/17/09 06:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Could be heater core or could be blend door. There have been a number of post recently about this. You might try a search to find them. I'd use a waterhose instead of compressed air. You won't risk blowing the core apart that way.
Re: No Heat in my 94 Dodge Ram [Re: stumpy] #196331
01/17/09 07:06 PM
01/17/09 07:06 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
https://board.moparts.org/ubbthreads/show...rue#Post4854154 I have reveresed the hoses and flogged the throttle and unplugged one, I have also used compressed air regulated down to remove abstructions
Re: No Heat in my 94 Dodge Ram [Re: Bob_Coomer] #196332
01/17/09 07:10 PM
01/17/09 07:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make sure the temp control knob is not broken,
Re: No Heat in my 94 Dodge Ram [Re: NITROUSN] #196333
01/17/09 08:18 PM
01/17/09 08:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I just switched the hoses on my 91 dak a couple weeks ago and it helped a ton.
Re: No Heat in my 94 Dodge Ram [Re: HotRodDave] #196334
01/17/09 08:31 PM
01/17/09 08:31 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had problems with my minivan just like that. It turned out to be a small leak in the rad. tank and not enough water for the heater to work. Gauge was not hot either. Filled it up and heater worked. Changing the rad was not too bad but better than messing with the heater core for sure. Check to be sure.
