Re: 420cid build with a new Ritter Aluminum Block
[Re: WHITEDART]
#1961185
12/01/15 08:02 PM
12/01/15 08:02 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
It is in my opinion🎲🎲 the oil galley should have just broke through into the lifter .or done like a typical r3... not dead center
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 69 lawndart]
#1962254
12/03/15 04:17 AM
12/03/15 04:17 AM
Posts: 2,864 IN
Irun5snd8th
IN
Keep the updates coming. I'm interested in one if they work.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: 69 lawndart]
#1963156
12/04/15 03:13 PM
12/04/15 03:13 PM
Posts: 2,864 IN
Irun5snd8th
IN
Kind of easy to see here why it would have drainback issues.
[Re: WHITEDART]
#1963200
12/04/15 04:11 PM
12/04/15 04:11 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Did you use a grooved lifter or bushin, so the oil could pass by 100% of the time. Because the oil galley is dead center of the lifter a groove someplace is necessary.. I used a grooved bushing. So that oil will pass by continuously Are you saying that the galley drilling goes straight through the lifter bores? As in... The first lifter blocks oil to all the rest!?
[Re: 69 lawndart]
#1963464
12/05/15 12:02 AM
12/05/15 12:02 AM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
Welcome to MoParts, Mike! So glad to see you getting this new bullet ready for your awesome Dart. Can't waiting to hear it singing through the gears on Drag Week again. Best of luck to you! I hope that third times a charm for me to get my 'Cuda to Drag Week in 2016. Had a lawn sprinkler Indy BB head put me down for 2015.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 69 lawndart]
#1970232
12/15/15 04:25 PM
12/15/15 04:25 PM
WHITEDART
bean town ....Ca
I don't think a slotted bushing would be in your best interest you need a bushing that has a circular groove so the oil can pass by both sides of the lifter not through it. I will try to post a picture
[Re: WHITEDART]
#1970234
12/15/15 04:29 PM
12/15/15 04:29 PM
WHITEDART
bean town ....Ca
The bushing on the left allows oil to pass by 100% of the time I think that's what you need that's what I had to do
[Re: WHITEDART]
#1970237
12/15/15 04:33 PM
12/15/15 04:33 PM
WHITEDART
bean town ....Ca
You can ignore the up and down slot that's for a keyway lifter you just need a typical grooved lifter bushing unless you're running a keyed I had to go to a large lifter to correct the location. And angle... lifter timing would have not been correct if we did not fix that problem hopefully you don't have that issue... most people would never check...
[Re: 69 lawndart]
#2029217
03/11/16 03:03 PM
03/11/16 03:03 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
Up date the bushing are installed and honed to size. after a trip to the machine shop for a good cleaning then home to begin reassembly. Will keep you posted.
[Re: 69 lawndart]
#2029612
03/12/16 02:21 AM
03/12/16 02:21 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Can't wait to see it on dyno
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 69 lawndart]
#2029700
03/12/16 11:25 AM
03/12/16 11:25 AM
WHITEDART
bean town ....Ca
Up date the bushing are installed and honed to size. after a trip to the machine shop for a good cleaning then home to begin reassembly. Will keep you posted. nice work who did the machine work. Do you have a pic of both decks I would like to see if he made any changes
[Re: 69 lawndart]
#2031657
03/15/16 02:25 PM
03/15/16 02:25 PM
dogdays
