Re: Best way to clean Cometic head gakets
[Re: JUST_N_TIME]
#196318
01/17/09 07:35 PM
01/17/09 07:35 PM
Posts: 4,701 On the parachute mount
n20mstr
i use them dry, per the instructions. I washed them with a mild degreaser then soap and water. I dried them with a paper towel, made sure there was no lint on them and re-used them
....BAD A$$ STREET CAR.....
[Re: drag440]
#196321
01/18/09 03:30 AM
01/18/09 03:30 AM
Posts: 977 Colorado
506RR
Colorado
I've never reused head gaskets before, this is new to me. I can see reusing them on the same block with the same heads etc., But reusing them with a totaly different head is spooky.
That was my thought when I went to new heads on my current motor. I didn't want to take the risk of them leaking with different heads so I just bought new ones. But, I kept the old ones just in case I ever get brave and decide to re-use them at some point. If it were me, I would buy new ones rather than risk them leaking once they are in the car. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: rebel]
#196323
01/18/09 09:55 AM
01/18/09 09:55 AM
KOS
i reused a set of cometics with copper coat 9 times before i experianced a failure. was a lil dissappointed, i was hoping to get 10!
same here where on 6 reuses on a sbc no failures and 3 on a sbm. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Hyper Henry]
#196326
01/18/09 01:50 PM
01/18/09 01:50 PM
Posts: 4,647 aotearoa
rebel
aotearoa
I herd you should drill the rivets out and take them apart and coat each layer with copper spray. Is that correct I am getting ready to reuse a set as well. Only second resuse for me.
![](/ubbthreads/images/graemlins/beer.gif) Derrick
correct! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rebel]
#196328
01/18/09 05:04 PM
01/18/09 05:04 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
correct!
I just used this process with mine today at BG's place. We will coat each layer.
