Re: Valve covers - From what???
[Re: aar1]
#196301
01/17/09 11:17 PM
01/17/09 11:17 PM
Posts: 6,301 colorado
a12superbee
colorado
Not if you're trying to do it the right way. By 'right' I mean all the wiring/plug wire tabs, pvc, all that stuff to be in the proper place to use all the factory accessories. If you're not worried about any of that, use whatever fits the engine.
I can't afford this.
mark
[Re: 72roadrunnergtx]
#196304
01/18/09 10:00 AM
01/18/09 10:00 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
The orange one is a 70/early 71 non-HP cover. The two in the center is a set of 71/4 non-HP covers for both B/C body. Can't really see but if the right one is raised in the center then it's a late cover,75/8. The cover them selves are year specific, not car specific. The difference is between HP and non-HP on the drivers side cover. HP does not have the plug wire looms.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
