There are several decent options, for a street and strip deal with moderate valve spring pressures, under 700 lbs open and below 7500 RPM I would go with a really good set of regaular solid roller lifters, not the cheapest ones
and make sure the rocker arms are oiled full time
Two options on that, one is to have the number four cam journal grooved on a lathe all the way around the width of the stock oil hole in the cam and around .030 deep or so or have tha block cam journal groove behind the #4 cam beaing, I like option # 1 the best
There are several other ways to do that but those two are probally the easeist way for most shops to do. As far as bushng the block if it is a 440 block and your shooting for under 700 HP on pump gas and no power addere plans don't waste your money on bushing the block until you find out if it needs it or not
I had one 440 block bushed years ago before I found out that the average 440 block main webs will fail if you push those blocks much above 750 HP N/A
Good luck on your build
Ss far as choices for building a good pump gas 440 block motor you might want to rethink your combination on your other post, I like and use the 4.25 stroke with 2.200 rod journal sizes and 7.100 long BB Chevy type H beam rods with the .990 wrist pin sizes, that reduces the grinding needed to clear the rods in the bottom of the block as well as it reduces the rotating wieght of the motor compared to the Mopar 2.375 size rod journals with those heavier rods and that 4.150 storke crankshaft and heavier, longer pistons
IHTHs
