Not disagreeing with oiling the top end full time. Bleeding of the #4 main and the two rods is where the issue is. Feed the heads from the main galleys. Don't put the bottom end at risk for something that is easily remedied with a simple drill and tap.
"use it 'till it breaks, replace as needed"
