Sealed hub growl...which side?
#1962431
12/03/15 03:54 PM
12/03/15 03:54 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
Need some help confirming my theory here before I dig into this... 4wd truck with cv axles and sealed hub units. Has what sounds like a bearing howl in the front end. The howl stays on right-hand turns but disappears on left-hand turns. Which bearing is bad? (I see this as a "bearing issue" as opposed to a "truck issue" so I put it here.)
Cheeto It's not perfect. It's not correct. It's not yours!
Re: Sealed hub growl...which side?
[Re: Cheeto]
#1962433
12/03/15 04:01 PM
12/03/15 04:01 PM
Posts: 4,748 Star Idaho
67vertman
Star Idaho
The one that is howling? My Bad, just being a smart...as$
I would think the passenger side! but if you are going to replace one side you may as well do both.
My Monster are real!
Living within your means makes life pretty easy.
[Re: Cheeto]
#1962436
12/03/15 04:03 PM
12/03/15 04:03 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I would tend to think it is the left hand (drivers side) hub making the noise because in the right hand turns the left hub is moving more. But, unless money is an issue, I would do the left first and then the right because it is going to go next.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1962449
12/03/15 04:21 PM
12/03/15 04:21 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
If noisy on RH turns, it is the left side which needs replacement.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: Cheeto]
#1962510
12/03/15 05:12 PM
12/03/15 05:12 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
My original post should've said "before I dig into this again". I've already replaced the side I thought was bad...I thought wrong. The hubs are $130 each. In this instance I'd have preferred to only replace the bad part but that ship has sailed. This is now a poll of sorts (to help my ego if others felt the same one was wrong as I did) and a learning experience for others to avoid my fate. The coil spring test is a good idea. Unfortunately this has torsion bars. I did jack it up and spin the wheels first. The side I replaced made only a slight bit of noise. Neither side had slop when wiggling the tire at 12 and 6.
[Re: Cheeto]
#1962513
12/03/15 05:13 PM
12/03/15 05:13 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Many are loose also.Jack it up and see if the wheel moves.replaced a lot at work especially GMs.The cheap bearings dont seem to last so get a quality one.We used mostly Advanced.I believe they were Timkens.Rocky
Chrysler Firepower
[Re: moparjim79]
#1962699
12/03/15 10:22 PM
12/03/15 10:22 PM
Posts: 9,835 MI, usa
dvw
MI, usa
My rule of thumb. When working on suspensions, both sides of vehicle are treated to same repair. Period. You are spending unnecessary money. Mileage and age are often kind to front end parts. My 64 Belvedere drag car needed only bushings. My 198,000 D350 has only needed 2 lower balljoints, My 73 Challenger one lower ball joint and bushings. I spent 27 years as a dealer tech specializing in chassis, axle, suspension. Doug
[Re: Cheeto]
#1962848
12/04/15 01:35 AM
12/04/15 01:35 AM
Posts: 586 UP
finn
UP
I replaced the right one on my Ram.
The left one failed within 9 months and almost left me stranded.
Chnged the right one on the Focus in August. The left one is noisy now.
Change them both
[Re: dvw]
#1962876
12/04/15 02:22 AM
12/04/15 02:22 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Most times it is the opposite side bearing from the direction the vehicle is being turned. But not 100%, I've been burned before by that. If the truck has front coil springs jack the front end off the ground. Rotate the wheel with one hand while grasping the coil spring with the other hand. The coil spring will resonate in on the side with the bad bearing. Doug I know what you mean Doug as I have been fooled before on that. I always put the car in the air and run the wheels while putting my mechanics ears up to each hub and I can usually tell very easy for sure like that. Ron
[Re: Cheeto]
#1963867
12/05/15 06:02 PM
12/05/15 06:02 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
Well I was in the same boat as many here. I thought that the bad bearing would get quiet when "unloaded" going around a turn. In this instance it was just the opposite. The bearing went quiet when more pressure was put on it during a turn. This seems counter-intuitive to me but "them's the facts"...in this case.
As for some of the other comments: -This was an auction purchase with new tires. No known history. Maybe other hub would go bad soon, maybe it was changed a year ago. -It wasn't my money I was spending. I was helping somebody else. We gambled on what seemed like logical troubleshooting and lost. So be it. Hopefully somebody else can learn from it.
