Re: PPP shifter, forward or reverse pattern?
[Re: mikeysmopars]
#1962654
12/03/15 09:12 PM
12/03/15 09:12 PM
Posts: 422 Columbus, OH
Ben Holt
Columbus, OH
If you have a reverse manual valvebody, this is how I sell it....
If you are going to manually shift it all the time, get a "push" pattern shifter. Cable comes out the front of the shifter, into the back of the trans. High gear is away from you and Park is closest. Just a nice bump of the shifter to upshift.
If you are going to pneumatically shift it, get a "pull" pattern. Cable comes out the rear of the shifter. Park is forward, High is closest to you. Just a quick 2-3 is all you need in the burnout, and it's a little more natural.
For every one of the "push" pattern shifters I sell, I sell 10 of the "pull" patterns, but either way you can't go wrong with a PPP
[Re: mikeysmopars]
#1962657
12/03/15 09:18 PM
12/03/15 09:18 PM
Posts: 20,207 Park Forest, IL
slantzilla
Park Forest, IL
My KS 2 is a push pattern, rear exit cable and front entrance on the trans. I was told this was the only way I could get it.
[Re: mikeysmopars]
#1962794
12/04/15 12:24 AM
12/04/15 12:24 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
rear exit at shifter, rear entry at trans, reverse pattern w/t air, clean N..... and a lil tip, IMHO the bracket for the cable mount at the transmission for the rear entry cable from PPP sucks! I'll give you mine if you want it, but I'll show you the simple way I did it.... fabbed up a bracket similar to this out of aluminum. Dropped it with a customer of mine that welds aluminum. He also meticulously restores BSA motorcycles and couldn't bear to work on a hacked piece and fabbed this up for me from mild steel the bracket from PPP bolts on using the pan bolts and gets in the way of a CSR shield belts.
[Re: Ben Holt]
#1962823
12/04/15 12:59 AM
12/04/15 12:59 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
For every one of the "push" pattern shifters I sell, I sell 10 of the "pull" patterns, but either way you can't go wrong with a PPP Is it too late to make the GTX a 4 speed car so I don't need to deal with this??????
[Re: Streetwize]
#1962867
12/04/15 02:12 AM
12/04/15 02:12 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I run a T/A cheetah RVB with a forward pattern gate, I actually prefer it since the 1-2 detent can't accidently go into High which seems to be one of the general complaints of the RVB pattern. The 1-2 has a positive stop (shift it as hard as you like and you can't miss) and the spring loaded gate swings out for the 2-3. the 2-3 is usually a bit more leisurely than the 1-2 so I never felt any disadvantage.
What I dislike about a RVB is you wind up two gears from neutral once you're in high and coasting through the traps for the turn-off. But that may not be the case with the PPP Wize do you have to push the shifter forward to shift with that setup or does it still pull back towards you ? Thanks , Ron
[Re: Streetwize]
#1962907
12/04/15 03:10 AM
12/04/15 03:10 AM
J_BODY
aZLiViN
Mike is going with a clean N t-brake P-N-1-2-3-N. I also used my old T/A Cheetah shifter with this set up and probably the same gate you have Wise. Just happen to be at the right place at the right time and this PPP air shift came up for sale. I really like it!
[Re: markz528]
#1963007
12/04/15 11:52 AM
12/04/15 11:52 AM
Ben Holt
Columbus, OH
For every one of the "push" pattern shifters I sell, I sell 10 of the "pull" patterns, but either way you can't go wrong with a PPP Is it too late to make the GTX a 4 speed car so I don't need to deal with this?????? I would prefer you did that Mark....hahaha. Real men use 3 pedals
[Re: Streetwize]
#1963035
12/04/15 12:43 PM
12/04/15 12:43 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
What I dislike about a RVB is you wind up two gears from neutral once you're in high and coasting through the traps for the turn-off. But that may not be the case with the PPP I do the same thing with my JVX (Winters) shifter. It's a front exit, rear trans entry, gated shifter that uses the tab on the trans and a bracket similar to the one J body uses. When I had a forward pattern VB in the trans sometimes on the 1-2 shift I'd go 1-3 with it being spring loaded. Now with the reverse pattern VB I've never missed the 1-2 shift, straight back for 1-2, then over and back for the 2-3, works for me. There have been a couple times I almost bought used PPP shifters but just couldn't pull the trigger.
[Re: Ben Holt]
#1963108
12/04/15 02:16 PM
12/04/15 02:16 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
So - I think I want to swap a TB, clean neutral, air operated, rear exit, rear entry Powershifter for a forward pattern (TA LBA manual VB) rear exit, rear entry Kwik Shift I (no air shift, no TB). I need PN 434 with rear exit option?. Shifter currently in the car looks just like J-body's, don't want to use brake right now....
This space not for rent.
[Re: mikeysmopars]
#1963585
12/05/15 03:30 AM
12/05/15 03:30 AM
J_BODY
aZLiViN
As with any build Ben..... always something different. Looking at the OP's picture in his post (Mike) I'm betting with the way his collectors are positioned the PPP rear entry bracket will be A-ok. My car has a tube K and no torsion bars, but the collector and bullet mufflers are still pretty close to the trans. That's where I ran into issues, and assumed that anybody with under chassis headers and god forbid.... torsion bars, would certainly run into issues. Either way, make a simple bracket as I did, and you can still drop the trans pan without having to mess with the shifter. Here's what I saw as I was trying to do the install (had to dig in the scrap pile to find one of those yuccy big block cases ) This is basically how the strap on the CSR shield would have to be installed with the bracket "As is". had another pict with a pan installed, but you get the drift. Cable runs over the strap and strap runs over the bracket. Yes.... interference with the N safety switch, but no prob... the shifter will have the features needed so you can basically plug this hole. In my situation, or the TTI user as you noted, you are going to need that strap tucked close to the trans. This is where a little minor trimming can get you the room. This bracket is solid as delivered (should have gotten a "before" pict). I cut the corner off the bracket, and then the slot to accommodate the CSR shield strap: once that was done, the strap can be routed through the bracket which still allows it to run under the shift cable... even more so with the slot. Either way.... the PPP is a dang nice shifter and I hope this aids someone with some helpful insight.
