Gen III Valve Cover Options #1957625
11/25/15 12:31 PM
11/25/15 12:31 PM
USA
hudsonhornet7x Online content OP
hudsonhornet7x  Online Content OP
USA
Lets see your valve covers installed on your engines. Do you guys like the stock covers or aftermarket?
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1958636
11/27/15 02:19 AM
11/27/15 02:19 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
How many Billet versions are available? I thought about making some in the new year
Alan Jones
Re: Gen III Valve Cover Options [Re: LA360] #1958927
11/27/15 08:18 PM
11/27/15 08:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
wrench
Re: Gen III Valve Cover Options [Re: sixpackgut] #1959017
11/27/15 11:28 PM
11/27/15 11:28 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted By sixpackgut
wrench
Saweet...Is that an intercooler sandwiched in there?
Re: Gen III Valve Cover Options [Re: Dragula] #1959202
11/28/15 01:45 PM
11/28/15 01:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
wrench
Yes LS parts with indy intake and adapter.
Anyone of you guys on fb should join a group G3 hemi swap. Lots of cool things people with are doing
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1960480
11/30/15 10:30 PM
11/30/15 10:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Moroso makes a nice valve cover for us
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1962364
12/03/15 01:38 PM
12/03/15 01:38 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I have modified Indy covers on mine.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1962420
12/03/15 03:35 PM
12/03/15 03:35 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
Joe, that looks so bad a@@
What do the heads flow and what camshaft are you using?
1971 6.1 Gen III Hemi Duster
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1962642
12/03/15 08:45 PM
12/03/15 08:45 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
Heads are ported early 5.7L heads, I have to find the flow sheets but they flow well for the "crappy" heads. I built the engine originally in 2007 so I used what I was able to get ahold of. Cam is a custom Comp. I am cutting and pasting my email from comp. Its a bit over cammed for a built stock cube engine but that's what I wanted. SERIAL # T 2124-10 SPEC CARD # 18101610 SPEC CARD INQUIRY BY SERIAL #
PART # 112-000-11 CAMSHAFT, CRH57 SPECIAL GRIND ROLLER
CORE C112-13A CAMSHAFT BLANK, CRH57 5.7L DODGE Q&T Special Grind
GRIND # CRH57 3536 /3547 HR107.0
DURATION @ .050 INTAKE 243 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 257 INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3450 EXHAUST 1.60
VALVE LIFT INTAKE .552 LOBE LIFT EXHAUST .3360
VALVE LIFT EXHAUST .537 LOBE SEPARATION 107.0
DURATION .006 INTAKE C/L 102.0
TAPPET LIFT INTAKE 299 CAM ADVANCE 5
TAPPET LIFT EXHAUST 319 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 19 JOURNAL DIAMETER STD 2.244
VALVE OPEN EXHAUST 60 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 43 DEPARTMENT P
VALVE CLOSED EXHAUST 16 SPC INSTR FOR CUSTOMER
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1962647
12/03/15 08:52 PM
12/03/15 08:52 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
Sorry for the hijack OP!!
[video:youtube]http://youtu.be/8oqSSfW4MRo[/video]
Re: Gen III Valve Cover Options [Re: Hemijoejr] #1964340
12/06/15 01:38 PM
12/06/15 01:38 PM
Dragula Offline
Dragula  Offline
That is awesome, what do you shift that at, and what size carbs?
Re: Gen III Valve Cover Options [Re: hudsonhornet7x] #1965282
12/08/15 12:29 AM
12/08/15 12:29 AM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I shift at 7400 and the dual quad cross ram carbs are 650cfm.
