1970 e body speedometer #1962139
12/03/15 12:09 AM
12/03/15 12:09 AM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
I haven;t driven my 70 challenger in years....I took it for a ride and the speedo is making a loud high pitch noise. The needle is going up to around 30 and swinging back and forth. I unplugged it so it wouldn't keep happening. Now what?
Re: 1970 e body speedometer [Re: z70dodge] #1962157
12/03/15 12:43 AM
12/03/15 12:43 AM
Kirkland, Washington
Pacnorthcuda Offline
The cable is binding up. You could remove it and lubricate, re-install while taking care to keep bends as gentle as possible, and/or replace the cable.
Re: 1970 e body speedometer [Re: Pacnorthcuda] #1963360
12/04/15 09:23 PM
12/04/15 09:23 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
The cable is spinning when I take it out and drive. I think its the speedometer itself. Do these usually go?
Re: 1970 e body speedometer [Re: z70dodge] #1963447
12/04/15 11:42 PM
12/04/15 11:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just because the cable is spinning doesn't mean it's not binding up some. Pull the cable core and clean and lube it. Hook it back up and see what's happening.
