6 cylinder to 318 transmission linkage #1962130
12/03/15 12:00 AM
12/03/15 12:00 AM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
I put a 318 in my slant 6 70 challenger. I want to keep the auto on the column. Is the linkage different from the 6 cylinder to the 318? Any diagrams on these or part numbers? Thank you....
Re: 6 cylinder to 318 transmission linkage [Re: z70dodge] #1962136
12/03/15 12:07 AM
12/03/15 12:07 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you used a 904 the shift linkage should be the same. The kickdown linkage will be completely different.
Re: 6 cylinder to 318 transmission linkage [Re: slantzilla] #1963364
12/04/15 09:25 PM
12/04/15 09:25 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Ok thanks thats great. Do you know the set-up or have a diagram for it?
