Page 2 of 3 1 2 3
Re: 727 and burnouts [Re: PC-CHARGER] #1961398
12/02/15 12:45 AM
12/02/15 12:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By PC-CHARGER
The major reason for a non LBA valve body is to eliminate overlap in the 1-2 shift. In an LBA valve body the low reverse band has to release while the intermediate band applies. If the release of the LR band is too fast or the INT band to slow, you will get a flare in the shift. If the opposite is true, you get a bind up. Even when it is timed perfectly, there is still a short period of time when they are both applied and cause a slight delay in the shift.
In a non-LBA valve body, the sprag or roller is holding the LR drum and when the shifter is moved to second the Int bad applies and the roller clutch unlocks as it is turning in the direction in which it freewheels so the release is immediate. No overlap to deal with.
This is correct and is why RMVB were no low band apply for many years. Basically a faster shift and no worrying about any shift overlap from two elements on at the same time. You wont get a flare but you can have a drag if the kickdown (second gear) band applys before the L/R band releases. It wont flare if the L/R band releases to fast because the overrunning clutch (sprag) will still be holding just like in a no low band apply. Ron
Re: 727 and burnouts [Re: Tempest] #1961548
12/02/15 07:14 AM
12/02/15 07:14 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
Excellent info guys! Many thanks.
Now I know why things are the way they are and I can rest peacefully thumbs
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: 727 and burnouts [Re: Tempest] #1961802
12/02/15 04:26 PM
12/02/15 04:26 PM
A727Tflite Online content
A727Tflite  Online Content
I know about the issue with sprags and LBA or not, relating to shock, freewheel at 2X the RPM and taking apart the drum. There are plenty examples out there. My question is, does it seem this is predominately an issue w/ slicks and racing?
Back in the day, we used to do burnouts all the time in 1st, pedal the car on and off the throttle with street tires and I never once heard of a 727 coming apart on the street back then. Granted HP/TQ was not what it is now for a healthy 440 like now.
Just trying to get a better understanding if this is just a slicks/track issue as I've always started burnouts in 1st. The reason I'm asking, I now have a fairly quick 440 and guess at the very least I should add a blanket to the trans. But I have no plans to run slicks.
Its due to roller spit back and shock load. The ORC has rollers and waffle springs. Spit back comes from when the rollers get locked then unlocked then locked again - think wheel hop. Slicks will compound the problem since you load the ORC more each time after it is unlocked - then you either spin the ORC cam in the case or you cock the rollers then things go to Haiti after that.
When I started with Chrysler I authorized ALL the transmission replacements for the U.S. - and cop cars (especially NY cop cars) broke the ORC with regularity. And they didn't have slicks on them. They had manual low block out - that prevented manual low band apply even though the cops thought they had them in low gear.
Came from two basic events - running across railroad tracks deep throttle (wheel hop)while in first gear auto, and neutral drops.
Re: 727 and burnouts [Re: Tempest] #1961819
12/02/15 04:51 PM
12/02/15 04:51 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Moparts has scared the poop out of me with 727 explosions. I remember when I bought my first MoPar when I was 16, a '67 440/727 GTX, and thought it was bulletproof. All I ever heard was the 727 is a tough rugged mother, 8 3/4 tough as nails behind a Torqueflite. Didn't know anything about RMVB, but the car had one, which I figured out once I got it running.
Nice running 440, I used to put that sucker in low, punch it and absolutely annihilate the H78-14 white walls off the back of it. Had 6000 RPM in about 15 feet, didn't know better, it sure was fun, and that tranny snapped 2nd gear real nice. Never hooked in first, and never really pedaled it though. And never drove it really on the street much, just pulled it out and went around the neighborhood leaving H78 lines all over the road since it was rough and I didn't own it long.
Spend enough time on here and you think a 727 is a ticking time bomb made out of glass. I always thought it was the best 3 speed automatic. This site makes me afraid of a non-LBA 727. Maybe I got lucky. I don't even like to go near the starting line when a 727 MoPar is launching now.
Re: 727 and burnouts [Re: Tempest] #1961824
12/02/15 05:00 PM
12/02/15 05:00 PM
Az
Crizila Offline
Crizila  Offline
Az
I went with a "cheetah" valve body. It has low band apply. Besides manual shifting, it will also up-shift automatically if you leave it in drive. I come out of the water box in drive ( 1st) and feather the throttle as it upshifts in to 3rd applying more power as I leave the box. Works great.
Fastest 300
Re: 727 and burnouts [Re: Crizila] #1961829
12/02/15 05:15 PM
12/02/15 05:15 PM
Norrland, Sweden
Norrland, Sweden
More excellent info!
Yes Transman, I didn't think of that, but wheel hop could certainly be a bad case with a non-LBA valve body.
Interesting Crizila, sounds like the Cheetah would be my type of valve body!
The more I learn, the more satisfied I am with still having the stock (although modified...) valve body! drive
Re: 727 and burnouts [Re: Swedcharger67] #1961835
12/02/15 05:25 PM
12/02/15 05:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As I tell everyone... DONT DO STUPID STUFF with
the 727 and it wont blow... I still have a stock
drum in the race car.. if you ever have to get
out of the pedal SHIFT IT out of low... I've had
this trans in it for 15 years and I have NEVER
blown up a 727(driving mopars for 50 years)
wave
Re: 727 and burnouts [Re: A727Tflite] #1961836
12/02/15 05:25 PM
12/02/15 05:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
So did it go into low and not apply the low/reverse band, or it just wouldn't go in? And they took the ORC out in 1st gear auto, but did that explode the drum? I'm a little confused.
Re: 727 and burnouts [Re: GTX MATT] #1961842
12/02/15 05:32 PM
12/02/15 05:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No.. you couldnt pull the shifter into low position.. it had
th blocker that didnt allow it.. the cops had a issue of
forgetting to shift out of low.. they would just float the
valves and half the time blow up the engines.. so the trans
was in low BUT the shifter was in second so it would shift
wave
Re: 727 and burnouts [Re: MR_P_BODY] #1961855
12/02/15 05:52 PM
12/02/15 05:52 PM
Norrland, Sweden
Norrland, Sweden
and since the cops couldn't have the shifter in manual low...the low band wasn't applied, and full throttle in 1:st while wheel hopping over railroad tracks caused the overrunning clutch (sprag) to freewheel momentarily and they broke the sprag...
Re: 727 and burnouts [Re: Swedcharger67] #1961858
12/02/15 05:54 PM
12/02/15 05:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They COULD have.. I never watched them on the job..
but most times they blew up the engines(before the
blocker)
EDIT
If I recall correctly they started putting the
blocker on in 74'
wave
Re: 727 and burnouts [Re: Swedcharger67] #1961869
12/02/15 06:06 PM
12/02/15 06:06 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Gotcha, but it didn't blow up the drum?
Re: 727 and burnouts [Re: GTX MATT] #1961880
12/02/15 06:13 PM
12/02/15 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It takes like 6200 rpm... if you blow the sprag
the drum will spin 2.2 times the engine rpm.. from
MOST testing on the drum it will self destruct at
13,000 rpm +/- some
wave
Re: 727 and burnouts [Re: A727Tflite] #1961931
12/02/15 07:16 PM
12/02/15 07:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure, we all did it but time is supposed to make us wiser. My very first 727 for pay was from a bone stock '69 Dart GTS 383 that rolled the sprag and took the case with it on the street.
Re: 727 and burnouts [Re: Tempest] #1961963
12/02/15 07:57 PM
12/02/15 07:57 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Why wouldn't a WOT downshift into first with the selector in D roll the sprag? Or can it? Sorry to hijack the thread but I can't help myself.
Re: 727 and burnouts [Re: Tempest] #1961979
12/02/15 08:23 PM
12/02/15 08:23 PM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
Update: So took car for a drive and it's a no low band MVB. So digesting all of this info, one last question:
Sounds like nothing short of a LRB valve body and billet drum will solve the problem. However, if I stick to 2nd gear burnouts, that will "reduce" my chances of catastrophic failure correct since if I do have a failure the drum will be at 6,500 instead of 15,000 RPM?
Not looking to change parts at this time, this is a street car. Just trying to find most appropriate way to keep it in one piece as I do drive my stuff hard. I am going to get a blanket just in case.
Re: 727 and burnouts [Re: Tempest] #1962007
12/02/15 09:09 PM
12/02/15 09:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once the trans shifts out of 1st gear the sprag just becomes a roller bearing...no load on it. Your car has the capability to do 2nd burnouts dry?
Re: 727 and burnouts [Re: Tempest] #1962027
12/02/15 09:30 PM
12/02/15 09:30 PM
Tempest Offline OP
Tempest  Offline OP
Thanks John for the info.
Yes it should do a dry burnout in 2nd. Rear is 4.56 and the street tires are 31". I have a line lock and it absolutely kills the tires on a roll in 2nd. Car went 11.42 @ 125 on the radials through the exhaust, so it seems to be making some decent power for a street car.
I recently acquired the car, so have not had a lot of time trying different things. To date, was launching in 1st, pedaling car in 1st and shifting to 2nd, pedaling again to get it to hook. Will try it this weekend with a 2nd gear dry start and let you know what I find out.
Re: 727 and burnouts [Re: MR_P_BODY] #1962043
12/02/15 09:49 PM
12/02/15 09:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Ugh. I remember those days. Had a fleet of Diplomats set up that way - with 360's in them. Actually some of the best squads we ever had from a non-destructible drive train stand point. Suspension / steering was another story.
Fastest 300
Re: 727 and burnouts [Re: Tempest] #1962055
12/02/15 10:17 PM
12/02/15 10:17 PM
With all these cars making the power that everyone says they make - DON'T DO A FIRST GEAR BURNOUT. Start in 2nd (shift to third if you are making lots of power) and when you feel the tires start to grab start to roll off the throttle to let the converter stator ORC start to catch up with things. Otherwise you will fail the converter ORC next.
Page 2 of 3 1 2 3
