Any way to straighten a warped plastic part? #196144
01/17/09 04:19 PM
01/17/09 04:19 PM
BDW Offline OP
BDW  Offline OP
Any suggestions to get this straight? It's an E-body heater panel. It's worse than the pic looks.
Thx
Re: Any way to straighten a warped plastic part? [Re: BDW] #196145
01/17/09 06:25 PM
01/17/09 06:25 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Heat gun or lamp.
Re: Any way to straighten a warped plastic part? [Re: BDW] #196146
01/17/09 06:34 PM
01/17/09 06:34 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I just fixed a warped part of a console...just sloooooowly warmed it up with a heat gun, then set some weight on it to hold the area in place for it too cool...worked great
Re: Any way to straighten a warped plastic part? [Re: OzHemi] #196147
01/17/09 06:46 PM
01/17/09 06:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I use one of my wifes old hairdryers. Doesn't get as hot as a heat gun so you won't burn or melt the part.
Re: Any way to straighten a warped plastic part? [Re: stumpy] #196148
01/17/09 07:05 PM
01/17/09 07:05 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
I've had success with boiling hot water before and there is no risk of "burning" the plastic.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Any way to straighten a warped plastic part? [Re: Fishmarket] #196149
01/17/09 11:06 PM
01/17/09 11:06 PM
BDW Offline OP
BDW  Offline OP
Thanks for the info,
How do you know it's hot enough, just keep heating until it's pliable? Do you guys do the whole part or just sections at a time?
As far as the cooling part, just let it air cool, or maybe put it in the freezer once it's straight?
Thx
Re: Any way to straighten a warped plastic part? [Re: BDW] #196150
01/17/09 11:09 PM
01/17/09 11:09 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I just let it air dry..
As for how hot...that is why I said slowly.. I just warmed up the area slowly until it was pliable enough to get to move...
Maybe practice on some spare plastic if you have it around?
Re: Any way to straighten a warped plastic part? [Re: BDW] #196151
01/18/09 12:35 AM
01/18/09 12:35 AM
Jacksonville Florida
elitecustombody Offline
Thx
it's better to keep trying to bend it while heating it up ,once it's warm enough and you get it back in shape,I'd hold it in bucket of cold water or hold it under cold running water if you have no access to compressed air,make sure to hold it in the shape wanted untill is cooled down
