Page 1 of 3 1 2 3
A518 46RE conversion for BB #1960771
12/01/15 08:47 AM
12/01/15 08:47 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
I'm kind of a newbie on this one and have found a lot of threads about the A518 46RH version but I've bought a A518 46RE transmission and Í'm looking for info.
I know have to use a JW Preformance Ultra-bell Bellhousing, part 92457 and have to fabricate a new transmission mount.
I heared that there are a few conversion kit and that a possiblity is going to full manual with a transgo shift kit.
What else do I need to make it work?
Re: A518 46RE conversion for BB [Re: dickdale] #1960899
12/01/15 01:50 PM
12/01/15 01:50 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Try to get the RH version. It can be controlled with two switches for lockup and overdrive. The RE version is electronic and you will need a standalone trans controller. The RH can be modified easier just like a 727 with shift kits, governors etc.
Carl Kessel
Re: A518 46RE conversion for BB [Re: dickdale] #1961044
12/01/15 04:28 PM
12/01/15 04:28 PM
BDW Offline
BDW  Offline
Yeah, I don't know if there is a stand alone controller available?
Re: A518 46RE conversion for BB [Re: dickdale] #1961064
12/01/15 04:48 PM
12/01/15 04:48 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
That's the point. I don't want to change to a RH. I'm looking for info on the RE model.
Re: A518 46RE conversion for BB [Re: dickdale] #1961084
12/01/15 05:04 PM
12/01/15 05:04 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As already said, the RE models require a controller to work. A Moparts member here was designing one. Here's a link to that thread.
https://board.moparts.org/ubbthreads/ubbt...design-one.html
There are two others I am aware of that also are capable of controlling the RE models. Here are links to those two.
http://www.firepunk.com/anteater/
https://www.powertraincontrolsolutions.c...ion_Controller/
Re: A518 46RE conversion for BB [Re: dickdale] #1961290
12/01/15 10:23 PM
12/01/15 10:23 PM
BDW Offline
BDW  Offline
Is there any performance benefits of the RE over the RH to justify the ~$800-$1000 controller?
Re: A518 46RE conversion for BB [Re: BDW] #1961436
12/02/15 01:17 AM
12/02/15 01:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not really as the RH uses a hydraulic gov and the RE uses an electronic gov. So the RE needs a controller to read the output shaft speed sensor and the gov pressure sensor. The controller has to duty cycle the gov solenoid to control gov pressure. On the RH is all done with the gov weights like on the 727 and 904. Ron
Re: A518 46RE conversion for BB [Re: dickdale] #1961499
12/02/15 02:51 AM
12/02/15 02:51 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I'll add my experience with the RE is it's not very reliable because of the lackluster attempt by Chrysler Engineering to make sure all the solenoids work without a hitch.
It's too much to get into, but their early attempts at combining the PCM control with transmission control was terrible.
Mo' Farts
Moderated by "tbagger".
Re: A518 46RE conversion for BB [Re: dickdale] #1961698
12/02/15 02:04 PM
12/02/15 02:04 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Is there any way to make the transmission work manually and operate the OD with a self controlled switch?
Re: A518 46RE conversion for BB [Re: dickdale] #1961715
12/02/15 02:23 PM
12/02/15 02:23 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Not that I'm aware of. You might check the Cummins or Turbo Diesel Registry forums as the trucks used both RH up to 95 and RE 96 on. The diesel people are working those over. All I've seen on the RE is that it needs a controller to operate it. The RH can get by with two switches, one each for od and lu. Another one to think of is the unit on the 91-93 diesel. It is od only, has no lock up converter. This would help on converter choices since it can use a standard unit that is readily available and less expensive than a custom lock up unit. Also since you are using a b-motor, find a trans that was behind either a diesel or V10. These ran internal components that would be the equivalent to a hemi 727. 5 pinion planetaries, more clutches, wider bands etc. Since you know you have to cut off the bell housing to put the trans bell on, this would be a better choice for your motor. Sun coast, Goerend bros are a couple of companies I know that do diesel stuff. Check with them. I would stay away from ATS. They have a bad rep for customer service issues. Not a good thing since you are across the pond.
Carl Kessel
Re: A518 46RE conversion for BB [Re: dickdale] #1961752
12/02/15 03:19 PM
12/02/15 03:19 PM
BDW Offline
BDW  Offline
Page 8 /9 has some info for RH controller
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Re: A518 46RE conversion for BB [Re: dickdale] #1961926
12/02/15 07:10 PM
12/02/15 07:10 PM
hooziewhatsit Offline
A basic RE controller will effectively be the same as a stock RH.
The main difference is that the shift points with the RH are set by the weights in the governor, while with the RE, they can be changed 'on the fly' based on the current load, transmission temperature, 4HI-4LO, etc.
Re: A518 46RE conversion for BB [Re: dickdale] #1962165
12/03/15 01:00 AM
12/03/15 01:00 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Not that I've heard of.
If you were to get a PCM from an later edition 2nd Gen Ram, and mimick the inputs from throttle position sensor, throttle valve cable, and vehicle speed sensor it could be possible.
I say maybe...........but, might as well go all the way and adapt all the fuel injection to your big block and have a "full loop" setup. Basically, you would be running a 2001 Dodge Ram factory system on your 383/400/440 to operate the transmission and get the added perk of efi.
Give you any ideas? devil
Mo' Farts
Re: A518 46RE conversion for BB [Re: dickdale] #1962264
12/03/15 06:05 AM
12/03/15 06:05 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
The trans is from a 1995 Dodge B250. Is it possible to use the controller from the B250 and put it in my 70's Plymouth?
Re: A518 46RE conversion for BB [Re: dickdale] #1962297
12/03/15 11:21 AM
12/03/15 11:21 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yes the transgo kit will work to make it all manual shift,, call & talk to them.
Re: A518 46RE conversion for BB [Re: CSK] #1962336
12/03/15 12:47 PM
12/03/15 12:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But you still need to deal with the Electronic Governor circuit.
Re: A518 46RE conversion for BB [Re: dickdale] #1962339
12/03/15 12:49 PM
12/03/15 12:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm sure it could be done, you'd need the controller, the wiring harness and the schematic and then you would need to install whatever inputs the controller needs to operate the transmission circuits.
Re: A518 46RE conversion for BB [Re: Grizzly] #1962342
12/03/15 12:51 PM
12/03/15 12:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a great idea but you'd need to redo the fuel mapping ...
Re: A518 46RE conversion for BB [Re: dickdale] #1962359
12/03/15 01:23 PM
12/03/15 01:23 PM
BDW Offline
BDW  Offline
Check the connector, if it's 3 pin its RH.
I got my 518 RH out of a 95 B3500
Re: A518 46RE conversion for BB [Re: dickdale] #1962383
12/03/15 02:20 PM
12/03/15 02:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the instructions that came with my transgo kit show how to convert the RE trans to full manual. CALL transgo, they are very helpful.
Page 1 of 3 1 2 3
