Front end rebuild ?..'68 B Body #196117
01/17/09 03:31 PM
01/17/09 03:31 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Is there any reason to replace the strut rods if they are straight, and the threads are undamaged.
Also the pivot shafts in the LCA.
They don't seem to be wear items but it never hurts to ask!
Re: Front end rebuild ?..'68 B Body [Re: moparrulzzz] #196118
01/17/09 03:59 PM
01/17/09 03:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I can't think of any unless you go aluminum to save a couple ounces??
Re: Front end rebuild ?..'68 B Body [Re: moparrulzzz] #196119
01/17/09 04:46 PM
01/17/09 04:46 PM
definitely not on the strut rods & only the bushing(rubber rather than poly is best on this particular area) on the LCA pivot shaft gets replaced. Pivot shaft itself is good
Re: Front end rebuild ?..'68 B Body [Re: moparrulzzz] #196120
01/17/09 07:40 PM
01/17/09 07:40 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
No reason to replace them if they are not damaged or bent.
Re: Front end rebuild ?..'68 B Body [Re: Lefty] #196121
01/17/09 08:23 PM
01/17/09 08:23 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx for the input guys. Just wanted to double check!!
