Page 1 of 3 1 2 3
727 and burnouts #1960147
11/30/15 11:05 AM
11/30/15 11:05 AM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
I know about the issue with sprags and LBA or not, relating to shock, freewheel at 2X the RPM and taking apart the drum. There are plenty examples out there. My question is, does it seem this is predominately an issue w/ slicks and racing?
Back in the day, we used to do burnouts all the time in 1st, pedal the car on and off the throttle with street tires and I never once heard of a 727 coming apart on the street back then. Granted HP/TQ was not what it is now for a healthy 440 like now.
Just trying to get a better understanding if this is just a slicks/track issue as I've always started burnouts in 1st. The reason I'm asking, I now have a fairly quick 440 and guess at the very least I should add a blanket to the trans. But I have no plans to run slicks.
Helpful comments appreciated.
Re: 727 and burnouts [Re: Tempest] #1960151
11/30/15 11:24 AM
11/30/15 11:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think you can get away with starting in 1st if you have a generic 727, but when you add some stall, MVB and such you really should start in 2nd. The Turbo Action instructions give you a good idea why. You can go to their website and print it out. I typically start in 2nd then hit 3rd at 5k and roll out of it and up to the line. You tires will spin faster and heat better in 2-3 than 1-2.
Coming soon!!!!
Re: 727 and burnouts [Re: Tempest] #1960189
11/30/15 12:43 PM
11/30/15 12:43 PM
Tempest Offline OP
Tempest  Offline OP
Just to reiterate, I'm talking about street driving, not track and heating tires. The trans is a built 727 with a MVB.
Re: 727 and burnouts [Re: Tempest] #1960205
11/30/15 01:29 PM
11/30/15 01:29 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Its been my IMPRESSION this is more of a problem with slicks since it is the shock of the slicks suddenly stopping the drivetrain motion that damages the sprag assembly.
It could be a problem on the street with sticky drag radials. Average street tires are too slippery for the drivetrain shocking.
That being said; I still make sure I'm not in first when letting off the loud pedal on the street out of habit.
"I think its got a hemi"
Re: 727 and burnouts [Re: Tempest] #1960230
11/30/15 02:21 PM
11/30/15 02:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you just want to do a burn out on the street I don't think you are going to hurt anything...
Re: 727 and burnouts [Re: Tempest] #1960760
12/01/15 07:15 AM
12/01/15 07:15 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
This is the way I understand the function of the 727.
You have 2 scenarios:
1. Gear shifter is in manual low (L)
2. Gear shifter is in D, first/low gear is active.
In case 1 the low band apply protects/locks the sprag, while in case 2 the sprag is active (no low band apply).
I believe the danger in case 2 is that while doing a burn out in low gear (shifter in D) a slight disturbance in the engine (like hitting the rev limit, misfire, fuel problem, or pedal the throttle) will/may cause the sprag to start free wheeling...and now a moment later when/if the full engine power is restored, the sprag will, with full power, slam back into locked position, and this causes a huge load on the sprag, and may destroy it.
So, never a burnout with the shifter in the D-position. A burnout in manual low (L) is a lot safer, if I understand things correctly.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: 727 and burnouts [Re: Swedcharger67] #1960790
12/01/15 10:29 AM
12/01/15 10:29 AM
Tempest Offline OP
Tempest  Offline OP
The question was regarding a reverse manual valve body trans.
Re: 727 and burnouts [Re: Tempest] #1960795
12/01/15 10:48 AM
12/01/15 10:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The question was regarding a reverse manual valve body trans. [/quote]
You start in second or high gear... heavy car.. start in
second... my car is light so I start out in high gear...
speed of the tire is what your after to heat it up
wave
Re: 727 and burnouts [Re: Tempest] #1961076
12/01/15 04:59 PM
12/01/15 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
LBA or no? Since most street burnouts don't involve a water box, trying to start a burnout in 2nd (depending on tires) will be a non-starter (pun intended) so you're stuck starting in 1st. If no LBA, you're laying with fire.
Re: 727 and burnouts [Re: John_Kunkel] #1961117
12/01/15 06:18 PM
12/01/15 06:18 PM
Tempest Offline OP
Tempest  Offline OP
Not sure on the LBA? I did not have the trans built. The car has a line lock and enough HP to kill the tires in 2nd, so I guess I will just have my fun in 2nd from now on. I'm still just wondering how we did all those street burnouts back in the day with 727's never having issues. I will do them in 2nd from now on. I like my feet!
Re: 727 and burnouts [Re: Tempest] #1961138
12/01/15 06:51 PM
12/01/15 06:51 PM
Norrland, Sweden
Norrland, Sweden
Maybe I'm missing the point in this discussion but even the standard 727 has LBA in manual low (L) as far as I understand.
Presumably a manual valve body has it too?
From my point of view it should be perfectly safe to start in manual low (L) and shift up when needed???
Re: 727 and burnouts [Re: Swedcharger67] #1961221
12/01/15 08:41 PM
12/01/15 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the LBA .. he would have to figure out who made
it and see if it it LBA... my old TA valve body is
a RMVB with a trans brake... it is not a LBA.. the
stock valve body is a LBA.. but you never know for
fact on a aftermarket RMVB... he can test it... put
it in low gear.. run up to 20 or so MPH and decell the
engine... if its a LBA it will slow the car with the
engine... if not LBA the car will just coast
wave
Re: 727 and burnouts [Re: Swedcharger67] #1961286
12/01/15 10:14 PM
12/01/15 10:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You presume wrong; I'll go out on a limb and opine that the majority of RMVB's don't have LBA. Easy to test, place the shifter in low, roll up to about 20 mph and throttle back to idle; if it has LBA the car will nose over under compression braking, if not, the car will just freewheel and coast with no braking effect.
Re: 727 and burnouts [Re: John_Kunkel] #1961308
12/01/15 10:54 PM
12/01/15 10:54 PM
Norrland, Sweden
Norrland, Sweden
I see, thanks for the good info.
It just seems very odd to me that the LBA-feature in the stock valve body would most likely be missing when investing in a RMVD. Maybe there is a technical reason for it...difficult oil routing in the VB, faster shifting, less drag or other?
Re: 727 and burnouts [Re: John_Kunkel] #1961333
12/01/15 11:29 PM
12/01/15 11:29 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
My manual valve body which has been in the car for 25 years has no engine braking in first gear. Turbo Action unit.
Re: 727 and burnouts [Re: Tempest] #1961357
12/02/15 12:10 AM
12/02/15 12:10 AM
Tempest Offline OP
Tempest  Offline OP
I will go and try the 20 MPH and off the throttle this weekend. If not, like I said, it's got the HP to kill the tires in 2nd on radials. smile
Re: 727 and burnouts [Re: Mr.Yuck] #1961369
12/02/15 12:20 AM
12/02/15 12:20 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Exactly how to do it at the track or on the street thumbs
If you have the power to start in top well do it. I have belted piss out of my 727's without a failure, street, strip, slicks, radials, strokers, nitrous and wheelstanding 9's. I have killed convertors, diff centres and axels though.
A car with a bit more HP may have a positive affect on trans as it have the wheels spinning with ease rather than struggling or labouring.
Love burnouts. Is there a burnout thread ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: 727 and burnouts [Re: Tempest] #1961370
12/02/15 12:20 AM
12/02/15 12:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I always started my burnouts in first before I got a line lock, it never really free wheels against the brakes and I shift to 2nd quickly. It took me 20 years to finally put a line lock on my car and now that I have one I start my burnout in 2nd gear. This is with a turbo action non apply manual VP
68 Barracuda Formula S 340
Re: 727 and burnouts [Re: Tempest] #1961376
12/02/15 12:24 AM
12/02/15 12:24 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Hey Tempest might be time to sweep the floor in there, it's looking a little untidy
1971 Barracuda
Re: 727 and burnouts [Re: Swedcharger67] #1961390
12/02/15 12:40 AM
12/02/15 12:40 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The major reason for a non LBA valve body is to eliminate overlap in the 1-2 shift. In an LBA valve body the low reverse band has to release while the intermediate band applies. If the release of the LR band is too fast or the INT band to slow, you will get a flare in the shift. If the opposite is true, you get a bind up. Even when it is timed perfectly, there is still a short period of time when they are both applied and cause a slight delay in the shift.
In a non-LBA valve body, the sprag or roller is holding the LR drum and when the shifter is moved to second the Int bad applies and the roller clutch unlocks as it is turning in the direction in which it freewheels so the release is immediate. No overlap to deal with.
Page 1 of 3 1 2 3
