Page 3 of 4 1 2 3 4
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: DaytonaTurbo] #1960703
12/01/15 02:55 AM
12/01/15 02:55 AM
Texas
P
pistonspeed Offline OP
P
Texas
Originally Posted By DaytonaTurbo
If I was starting from scratch, hands down a junkyard magnum 5.2/5.9 with a supercharger or turbocharger. 500+hp for pennies on the dollar compared to a comparable n/a SB or BB.
You know I gave this serious consideration - and may give it more consideration - but what initially scared me away from a turbo is the potential for turbo leaks in the piping and how in general more complexity = more problems.
That said, with 5-10psi boost on a 5.9 Magnum, even without an intercooler, that should be a 550hp motor.
I can't see a supercharger kit being cheaper than building a N/A big block though... I could be wrong of course.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: HotRodDave] #1960707
12/01/15 03:01 AM
12/01/15 03:01 AM
Texas
P
P
Texas
Originally Posted By HotRodDave
BBs don't belong in 12 second a bodys, not really even worth the hassle till maybe mid 9s. Simple jobs like spark plugs are not simple, you stuck with a 727 if you want an auto and they are heavy.
The Gen III hemi is awesome but sooooo expensive to get it in (motor mounts, headers, oil pan, EFI or carbs are both expensive and painfull when you count "good" intakes that will eat most of $1000, all the accessories evn from the JY are still expensive, aftemarket flex plate) if you buy a drop out with the harness and computer it is expensive and eats all the $4500 when you throw in mounts, pan, headers... and you might get 400 hp without breaking it open. It is the lightest option witch is good and you should get in the 12s.
A 408 is the easiest, cheapest most fun combo. Get a set of EQ heads from hughes under $1000 ready to run. Get a SCAT rotating assy with I beams and it drops in with no grinding needed. Get the roller reground at delta cams for under $100 the one I use most is 221@.050 110 LSA and pulls like crazy and will runs 12s easily in an a-body. Motor mounts, oil pans, headers... are a dime a dozen, plugs are easy to swap, you can run a 904 for more weight savings and eliminate the traction issues a front heavy BB has. If you can not run 12s with this and keep it under $4500 you are paying someone too much.
I tend to agree with you, but I just don't see a 408 being built for that cheap without using stock Magnum heads (which are typically cracked) and a cast crank... I'm sure that there's good cast cranks out there besides Eagle which are not prone to crack, but I just don't know if my comfort level quite there to spent that much money on a engine with a cast crank.
Last time I priced out a 408 with IMM heads and a forged crank, it was close to $6000-$6500.
I wonder at what price point a 5.7 Hemi swap would have to drop to be a wash against the 5.9 Magnum?
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960708
12/01/15 03:02 AM
12/01/15 03:02 AM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
360 small block. Stroke and bore it to 410 cubic inches with aluminum heads -- easy 500 horsepower and light weight. Power to weight ratio is a lot better with this combination unless you go with an aluminum hemi.
Best of luck!!!!!!!!
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: DeMopuar] #1960811
12/01/15 11:30 AM
12/01/15 11:30 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
I guess the main question is how are you going to use the car? Mainly street with the occasional 1320, autox, road course or is it going to be the occasional Friday/Saturday cruise with a visit to the track every weekend?
I faced this question several years ago with my 67 Dart GT. Since the car was mainly a street visitor And had manual steering I went with a 360. He built a motor that pretty much had the torque and hp equal to similar big block without the added front end weight. The car would go low 13s all day long and was limited in going faster due to chassis and limited rear tires and gearing.
The car is now in OZ, the new owner made some mods, went with a small block stroker tubbed the rear to get more tire, made some minor front end mods and now the car gos in the low 11s
Owning a big block Dart now I can see a vast difference in handling running a big block vs a small block A body.
Abe Lincoln
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960816
12/01/15 11:51 AM
12/01/15 11:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm a BB guy but for what you want a SB should do the trick and will be much less of a head ache.
Coming soon!!!!
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960850
12/01/15 12:33 PM
12/01/15 12:33 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I always liked the A bodies with the 383. I'd get a 383, build it to '68 magnum specs with 10.5 compression, mild hyd. cam and have fun.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960910
12/01/15 01:59 PM
12/01/15 01:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Superchargers aren't the cheapest things out there, however a good, new centrifugal supercharger can be had for 2500. The beauty is if your engine ever pukes, the s/c in not affected, can be resold, transferred to another car, etc. A used one can be had for 1000-1500 depending on model.
quickD100 has a post in the race section about how he took a stock LA 318, put on a $250 ebay GT-45 turbo, put in a new head gasket set, o-ringed the block, head studs and dynoed 563hp. Even with the extra complexities, it would be well worth for the cost savings. For 1000 bucks you could put the whole thing together. Worst case scenario you grenade the block and are out the $200 bucks for another junkyard 318.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: Jim_Lusk] #1960929
12/01/15 02:21 PM
12/01/15 02:21 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted By Jim_Lusk
440. This was a junkyard motor...still has NOT been rebuilt.
Jim, what exhaust manifolds are those?
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960941
12/01/15 02:31 PM
12/01/15 02:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'd say it depends on how much YOU can do, your capabilities, if not much you will pay the piper, keep it simple, 360-383 with good heads,cam, intake, carb and ignition. I'd be embarrassed if it didn't run 12s-13s. 100 hp shot nitrous would be easy to add. Get it running then as time and money allow upgrade the combo. If you can do the work get the Gen lll 5.7-6.1, sky's the limit for that engine. Stock transplant, 5.7 $1800 with fast controller $1300 mated to a 904, mounts, oil pan maybe another $600 you're on your way, use the stock headers. Again upgrade as money comes in. Scrounge around for deals on parts! Don't have to buy new! Get it running and you'll have your money pit. LOL
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: kenworth_goose] #1960955
12/01/15 02:48 PM
12/01/15 02:48 PM
cudadoug Offline
cudadoug  Offline
Originally Posted By kenworth_goose
360. I can build a stock stroke 360 that will put an A-body into the 11's easily. I've built a few, all the same build. 360std bore, KB 10to1's on stock 273 rods. I don't change balance at all. windage tray, stock pan. stock heads with fresh valve job, 508 purple shaft with roller tip adjustable rockers set lash at zero. Single plane torquer II intake, 750 DP holley with some bigger jets, squirters. Hooker headers. factory electronic dist with recurve springs. That's all I do. The first one I built ran in a full body, interior, exhaust, stock suspension 68 dart. Also had a stock convertor in a fresh 727 with shift kit and 3.91's. Very simple, cheap build that ran like crazy. It went 12.40's with zero traction over half track at over 115mph at the finish. If I had the chance to change the convertor, put the 4.30's in it and some sticky tires it would run mid 11's easy. Had over 435 at the wheels. You don't need strokers and big dollar fancy parts to go fast if the combo is made for each other. Want to see the car do a burnout? Go to youtube and lookup Kenworthgoose. WE were in Heath at the Chrysler dealer that year.
435 HP at the rear wheels?? That means you were over 500 at the flywheel...
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1960967
12/01/15 03:01 PM
12/01/15 03:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I assumed cleaned up, ported 452 heads.
The 408 builds I have looked into would likely require aftermarket heads (meaning $$$$) due to the crack issue with stock Magnum heads and the fact that you'd have to get the Magnum heads machined for LA-style intakes anyway.
Have you priced out rebuilding and porting stock iron heads , nevermind choosing the worst design possible ... an OPEN CHAMBER stock iron head ... it would be cheaper to buy a set of E brock heads than to redo iron heads.
I think you misunderstood me.
I meant ported 452s as in three-angle valve job at the most... hence just cleaned up.
Sorry for the confusion.
I think you have misunderstood then what the meaning of PORTED is, a 3 angle valve job is NOT porting.
It's still going to cost a lot to even do a basic rebuild on the CRAPPIEST head known to man, the open chamber, big block Chrysler head, there are stock small blocks heads that flow better.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: JohnRR] #1961384
12/02/15 12:33 AM
12/02/15 12:33 AM
Texas
P
P
Texas
It seems like you're just trying to start an argument with me at this point, which adds nothing to the discussion, especially since I had already apologized to you over the confusion.
But yes, I am aware that it's best to buy aftermarket big block heads than trying to perform a full-blown race port on factory heads.
However, for an engine that's likely not going to see more than 450hp and 500ft/lb of torque, it can be argued that just cleaning up and reusing a set of 452s would offer the best bang for the buck.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: DaytonaTurbo] #1961387
12/02/15 12:38 AM
12/02/15 12:38 AM
Texas
P
P
Texas
You make some good points. What's interesting is that with a quick Google search, a brand new NOVI-1200 supercharger is roughly $3,000, so installing that on top of a low mileage 5.9 Magnum wouldn't be more expensive than rebuilding a big block with similar HP.
And correct me if I'm mistaken, but with a turbo you dial back the boost if need be and turn up the power whenever you want it.
Hmm...
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: cudadoug] #1961451
12/02/15 01:36 AM
12/02/15 01:36 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
B-body HP. Those are '69 pieces, but '68-'73 will fit the same. The outer sleeve on the steering column has to be shortened up to the firewall.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1961498
12/02/15 02:49 AM
12/02/15 02:49 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
The engine I bought for my '68 Dart was an LA 360 (9:1 compression) out of a cop car from the 70's (apparently). It supposedly had a very mild rebuild in the 90's and was put in a Valiant. Sometime around 2008 the owner of the engine put a Paxton supercharger on it. The supercharger only made 4-5 lbs of boost but made 390 whp to the wheels. When I bought the engine, I first decided to send it to a machine shop to check as it had some leaks here and there and had kind of low compression on one of the cylinders. When he tore it apart he was shocked to see it had stock internals. When he checked the bores they were 0.003" out of round. I do feel like the engine did take a tole with the extra boost and hard running towards the end of its life.
Well, my engine builder and I talked it over, and for my application (someone who plans on autocrossing and road racing) we decided to go with a mild 408 stroker engine for the lighter weight, simplicity, and to free up more room in the engine bay. He projects it to make about 500-575 crank horsepower.
What I'm going to do with the supercharger? I'm either going to save it or sell it to recoupe my money. I had an interesting junkyard 273 I wanted to build or I thought it would be cool for a pre-75 small block truck as a tow rig I think the A-bodies really benefit from small blocks, but I will admit a big block does look cool in one.
If I was starting with a completely clean slate, I'd hands down go with a Gen III Hemi. If you really want to be different and have the patience with fabrication and tuning you could try doing an SRT4 swap. biggrin
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1961502
12/02/15 02:54 AM
12/02/15 02:54 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Hmm...
Same with a supercharger. Just swap pulleys.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: MuuMuu101] #1961554
12/02/15 08:37 AM
12/02/15 08:37 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Hmm...
Not the same.
Just finished getting a CSX sorted out after 6 months of work. I can alter the power from 150 hp to 270 hp with just a tap of the boost controller while tooling down the street.
"I think its got a hemi"
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: pistonspeed] #1961617
12/02/15 12:14 PM
12/02/15 12:14 PM
Manitoba, Canada
Manitoba, Canada
Hmm...
If you take a look on ebay, you can often find used centrifugal supercharger kits for 5.0 mustangs for pretty cheap (~1500). They would be a perfect fit for a 318 or 5.2 mag or 360/5.9. I bet for 2500 I could pick up a used kit, junkyard 5.2 magnum, fuel system, piping and bracketry and be out the door. Turbo could be done for a lot less, but a lot more work and skill required to setup the exhaust piping.
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: RapidRobert] #1961697
12/02/15 02:03 PM
12/02/15 02:03 PM
smyrna,tn
draginmopars Offline
smyrna,tn
Originally Posted By RapidRobert
400 block/offset ground 440 steel crank/MW ex manifolds. 470 cubes. see Andys' 451 manifesto in the archives
Just for info..
Manifolds won't fit the regular mounted way,
unless the firewall is move back.
swapped sides- move the master cylinder over.
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: What Would YOU Put in an A-body? Small or Big Block? [Re: gdonovan] #1961748
12/02/15 03:14 PM
12/02/15 03:14 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Hmm...
Not the same.
My knowledge on boosting engines isn't amazing, but I'm assuming if you have a boost controller, you also have some sort of on-board computer and fuel injection kit to dial in the boost and change the tune not to blow the engine. How do you do that with a carbureted system?
I'm assuming the op is budget minded as he keeps talking about cost. I know people say throwing on a turbo is cheap, but almost all of the budget builds I have seen have cost over $1500 and many more man hours.
Page 3 of 4 1 2 3 4
