help with conv identity #1957071
11/24/15 02:32 PM
11/24/15 02:32 PM
south central,Pa
mopar_to_ya Offline OP
south central,Pa
the ring gear says 47339E12 CH RG 130
It's a 10" conv
Trying to figure out what brand and all specs.
Any info appriciated
thanks
It's a bigblock with a torque flight!!!
Re: help with conv identity [Re: mopar_to_ya] #1957869
11/25/15 08:19 PM
11/25/15 08:19 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/429181/torque-converter.html
Have an idea that is a part/ID number for the ring gear that has nothing to do with the converter it's attached to. No other numbers? If not, it's a crap shoot. 5/16 or 7/16 bolts? External balance weight? Paint color?
Re: help with conv identity [Re: CMcAllister] #1958010
11/26/15 12:22 AM
11/26/15 12:22 AM
south central,Pa
south central,Pa
Hey Cole, what's new in your neck of the woods? It is black in color, and is a 10". It has 5/16 bolts. I was told it was ATI, but I called them and they never heard of a number like that.
thanks for the reply
Re: help with conv identity [Re: mopar_to_ya] #1959151
11/28/15 11:39 AM
11/28/15 11:39 AM
south central,Pa
south central,Pa
here is a pic, I'm sure someone has seen one like this before.
Maybe an Alambama conv???
Re: help with conv identity [Re: mopar_to_ya] #1960108
11/30/15 04:16 AM
11/30/15 04:16 AM
south central,Pa
south central,Pa
50,000 members and nobody has ever seen a conv like this? lol
BUMP
Re: help with conv identity [Re: mopar_to_ya] #1960125
11/30/15 07:01 AM
11/30/15 07:01 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
BUMP
Sure.......seen plenty. It's black and it's a torque converter. The number on the gear is likely just the gear number. With no stampings on either half...........yep, it's a torque converter and that's about all any one will be able to tell you.
I CAN tell you this, it's likely NOT an ATI. Never seen a company like that that doesn't stamp them. How would THEY even know what it was with no numbers on it. Lots of local trans shops built converters for people. Probably what that is. You want to know the "specs" somebody will have to cut it open and see what parts are in it
Re: help with conv identity [Re: mopar_to_ya] #1960255
11/30/15 03:17 PM
11/30/15 03:17 PM
BUMP
Let see, 10 inch converter with no I.D #s and 5/16 bolts, probaly a real cheap one like the old hated GER brand shruggy
Re: help with conv identity [Re: Cab_Burge] #1960397
11/30/15 07:48 PM
11/30/15 07:48 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ronnie, I see no-name 11" converters that look like that all over ebay for a couple hundred bucks. But no 10". Don't know anything else other than to have it opened up to find out exactly what it is.
Re: help with conv identity [Re: Cab_Burge] #1960555
11/30/15 11:47 PM
11/30/15 11:47 PM
south central,Pa
south central,Pa
I had a junk GER conv years ago, lol. It actually looked like a normall conv, but it was def a p.o.s.
I would like to find a brand that looks similar and call the company but, oh well. I'll just sell it or put it in something to check it.
Re: help with conv identity [Re: CMcAllister] #1960556
11/30/15 11:49 PM
11/30/15 11:49 PM
south central,Pa
south central,Pa
Yeah, Cole, that's why I took the chance on this one from a friend, because it is a 10"
Re: help with conv identity [Re: CMcAllister] #1961085
12/01/15 05:04 PM
12/01/15 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most 11" converters are based on factory cores where the ring gear attaches directly to the shell, ring gears attached with "spokes" like the pic are 10" and smaller.
Re: help with conv identity [Re: mopar_to_ya] #1961098
12/01/15 05:26 PM
12/01/15 05:26 PM
an8sec70cuda Offline
I've never seen one that was smooth like that one is.
Best thing is to have it cut open and inspected. My local guy will do that pretty cheap.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: help with conv identity [Re: mopar_to_ya] #1961197
12/01/15 08:16 PM
12/01/15 08:16 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
If nothing else, it would be interesting to know what it is. Seems you have the only one.
Re: help with conv identity [Re: John_Kunkel] #1961454
12/02/15 01:41 AM
12/02/15 01:41 AM
south central,Pa
south central,Pa
I guess I need another pic to explain what I'm thinking, lol. If that makes any sense at all. The bottom of the shell isn't radiused like most.
Re: help with conv identity [Re: mopar_to_ya] #1961596
12/02/15 11:19 AM
12/02/15 11:19 AM
NC USA
U
ultimatelenny Offline
U
NC USA
Hi, that is built off the 10" Chrysler 404 core mostly used by GER back in the day. Not the most desirable or dependable piece for sure.
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: help with conv identity [Re: ultimatelenny] #1962253
12/03/15 04:17 AM
12/03/15 04:17 AM
south central,Pa
south central,Pa
Well that figures, hahaha
Thanks Lenny
