When installing a cam...advance it? Retard it? Help. #1960118
11/30/15 05:17 AM
11/30/15 05:17 AM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Ok, little background info to get everyone up to speed. I just recently picked up a 77 440 out of a truck. Nothing special, low mileage that sat outside. Guy threw in a brand new .474 purple shaft and some 1.6ration PRW roller rockers. All for 100. Couldnt pass it up.
Well, I got the motor apart and everything looks great....except a hole in a piston. So a quick trip to summit...46 dollar piston, timing set, lifters and gaskets im almost ready to re-assemble this thing.
The timing set I boug has notches for either retarding or advancing the cam from 2-8 degrees.
Should I install the cam by lining up the dots? Advance it? Im lost as to what to do.
Its gonna be an 8-1 906 headed motor since this is what ive pieced together for very little money.
8-1 compression, .474 purple shaft, undecided on stock rockers or the 1.6 ratio (may just sell them) rpm air gap, 750 holley DP. Not looking to make huge numbers, its a budget motor that I have no idea what im going to do with.
So any advice on where to install the cam, which rockers I should use and any guesses on what kind of power this pig will make? Thanks in advance guys.
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960128
11/30/15 08:59 AM
11/30/15 08:59 AM
places
79powerwagon Offline
places
Myself, I'd set it all up stock (well, perhaps close to a pre-1973 spec). Make it a driver, have some fun with it, THEN think about a build to make that 440 a screamer! smile
And most importantly- have fun!
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960133
11/30/15 09:51 AM
11/30/15 09:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Advancing it will help crutch the low compression. I would make sure I degreed it though. In at 106-108
Doug
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960153
11/30/15 11:25 AM
11/30/15 11:25 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if thats the 280-.474 cam it's on 110lsa and has 4 degrees of advance ground into it. it should install at 106cl and thats were i'd put it in.
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960167
11/30/15 11:51 AM
11/30/15 11:51 AM
scratchnfotraction Offline
I went with the Hughes whiplash in my 440. it is great daily driver made to work with the low comp ratio.
once I got the dist recurved and initial of 18* with 18* of mech it turned into a beast.
sounds like a funny car at idle but drives like a stock BB with attitude on the street in my truck.
LSA 107*
IC 102*
dur@.050 232*/245*
lift 516/516 with 1.5 ratio
550/550 with 1.6 ratio
installed straight up running a stock low stall TC and 2.76 gears turning 29x15x15 M/Ts LOL! 12.5 mpgs 55=2000 rpm
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960178
11/30/15 12:21 PM
11/30/15 12:21 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Unless you check it with a degree wheel its just a guess. I'd use the 2 or 4 degree advanced keyway if just guessing. But I'd try to buy or borrow the tools to degree it. When it doesn't run that impressive the first thing everyone will tell you to do is degree the cam.
Sell the PRW rockers, use the money to buy correct length pushrods if needed and/or valve springs (definitely needed), and use the stock rockers.
With an RPM intake and 1.75 inch headers I'd guess that it would make about 350 horsepower tuned up nice. In an A body with sticky tires, 4.10s, and 3000 stall it would be a good runner.
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960210
11/30/15 01:38 PM
11/30/15 01:38 PM
use the 4 deg slot & that is 4 crank degrees even tho the squares/triangles & their reference descrip are on the cam gear (which as you know turns at 1/2 the crank amt) cuz all crank degreeing/anything related to that is done/measured in crank degrees on the dampener. when done dial in the dist subsystems: initial/total/springs/the can (if used & I would) IN ORDER. I had a low comp 440/509 MP cam (not a good combo but I was young and learning) & I milled the 906 heads 60 & adv it 4 deg and it woke it up
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960242
11/30/15 02:59 PM
11/30/15 02:59 PM
Those Mopar purple shaft 484, both grinds, are absolute junk, sell it and buy a good cam thumbs twocents If you do decide to try it make sure you degree it in, it will perform better for your deal installed at 4 degrees advance on the intake lobe center so make sure and check it scope twocents Don't ASS U ME it iwll be correct by using the marks on the crankshaft gear tsk I just went through degreeing a big solid lifter bracket cam this weekend and the cam dot on that gear would not align perfectly with the crankshaft gear,(very common on the Cloyes three bolt Mopar BB True Roller sets runaway) when I degreed it with the cam dot to the drivers side of the crank gear it was in at 118 intake lobe seperation, moving it one tooth on the cam gear towards the passenger side put it in at 107 intake lobe seperation shruggy scope
Re: When installing a cam...advance it? Retard it? Help. [Re: Cab_Burge] #1960262
11/30/15 03:30 PM
11/30/15 03:30 PM
I agree with Cab, I would not purchase a purple shaft cam & if you can degree or learn how to, it is highly recommended.
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960353
11/30/15 06:34 PM
11/30/15 06:34 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Well the cam was given to me with the purchase of the motor so I figured id run it, its new in the box still. I have a degree wheel and tools to degree it, just lacking the knowledge. The car already has a bs 440 in it that will be going the boosted route so this motor wont be going in the car and I need another project like I need a bullet to the head honestly. Kinda working with what I got deal. I will degree the cam and install it at 106. Not trying to break any records on power but I have access to do it on the cheap and possibly have a decent running motor for very cheap. Ill sell the rockers (theyre already listed on here anyways) and run the stock ones. Thanks to everyone that replied. I was kinda aiming in the dark on this one.
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960355
11/30/15 06:40 PM
11/30/15 06:40 PM
CT
CT
Not hard to degree them at all, instructions all over the net and always help here. Just need the wheel and a dial indicator. And once you do it once and have it down you'll do it all the time. up
Re: When installing a cam...advance it? Retard it? Help. [Re: GTX MATT] #1960357
11/30/15 06:42 PM
11/30/15 06:42 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
I dont mind learning new things too. Figure itll come in handy if I ever do another motor. I have a wheel and dial indicator just laying around that I never used (always intended to learn)
Now to decide if I need another car or not to put it in runaway
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960359
11/30/15 06:45 PM
11/30/15 06:45 PM
dogdays Offline
dogdays  Offline
You have the cam, use it. It's the best f the three because it doesn't have a ton of duration. Use the 4* advance slot. I don't believe those cams were ground with 4* built in. I'd use the 4* slot anyway. I'd use stock ropcker arms, easy and fail-safe with that cam.
Here are some "of course"s
Of Course you can buy a better cam, however the 474 is close to the Street Hemi grind that was popular back in the day.
Of Course you should degree in the cam, yet millions of cams have been installed dot-to-dot. You just won't get optimum performance, but you probably won't notice it either.
You got quite a deal, so enjoy it without making it into a Taj Mahal build that never actually runs as you follow everyone else's attempt to spend you broke.
R.
Re: When installing a cam...advance it? Retard it? Help. [Re: dogdays] #1960363
11/30/15 06:49 PM
11/30/15 06:49 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Budget is the name of the game with anything I build. Hence why I told everyone its getting used in the first post. Im a broke kid that wants to have fun at the end of the day. Well, at 24 I consider myself a kid still.
If I put it in a car and itll fry the tires and hold its own at a stoplight, well im more than happy. up
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960370
11/30/15 06:59 PM
11/30/15 06:59 PM
CA
crackedback Online content
crackedback  Online Content
CA
If it has a 110 lobe separation angle, I'd install it at 102-103 range to help the low static compression of your engine. It will make it run MUCH better at low end. Give it the initial timing it wants, dial in the curve and it will be a strong runner.
I've put the 108 LSA 484 cam in at 98-100 ICL on low comp engines. Some think it's crazy, IT WORKS!
ALWAYS degree a camshaft if you have the tools to do it.
Re: When installing a cam...advance it? Retard it? Help. [Re: GTX MATT] #1960405
11/30/15 08:09 PM
11/30/15 08:09 PM
Chicago
PurpleBeeper Offline
Chicago
I have to agree with GTX Matt.... cams can be advanced or retarded from the manufacturer. My purple 292/509 turned out to be 5-degrees retarded out of the box. Just degree it and set it up as designed (or very close) IMO.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960435
11/30/15 08:54 PM
11/30/15 08:54 PM
If you do degree the cam start at the intake lifter first, once you get that down then move up to the valve retainer and check the LSA on both the intake first and once you have the cam where you want the intake lobe center then check the exhaust lobe center thumbs twocents the reason I'm advocating that is to verify that the cam is ground on the LSA the cam card says it is scope I've had more than one cam ground wrong on the LSA, once you fight that war you will always verify the LSA on both thumbs If the cam is ground on a 108 LSA then when the intake lobe is advanced to 4 degrees advance and is at 104 max lift after top dead center the exhaust lobe should be in at 112 before top dead center for max lift scope If it, the exhaust lobe, is at 114 then the cam is not ground on 108 LSA workshruggy IHTHs thumbs
BTW, back in the days of the Direct Connection program Mopar sold the Purple Shaft 484 Street Hemi grinds for all their V8, after hearing many street people complaining about its lack of vacume at idle and the very choppy idle, lack of bottom end and so on they ended up adding the later "484 grind" non Street Hemi grind for the B and RB wedges thumbs I've never ran one of them but I do hear good things about that cam shruggy
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960455
11/30/15 09:16 PM
11/30/15 09:16 PM
Between a rock & a hard place
cudadoug Online content
cudadoug  Online Content
If you have the tools, you're 75% there already!
Watch this: Yea, it's a chevvvvy but the same logic applies,
https://www.youtube.com/watch?v=7cNoVRLb73c
Re: When installing a cam...advance it? Retard it? Help. [Re: 69B3GT] #1960507
11/30/15 11:11 PM
11/30/15 11:11 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
If you have the tools but are lacking the knowledge, go to youtube. There are some videos showing how it is done. Look at a couple of them because some of them are junk.
Re: When installing a cam...advance it? Retard it? Help. [Re: patosmith] #1960550
11/30/15 11:40 PM
11/30/15 11:40 PM
IN
ahy Offline
ahy  Offline
IN
Whatever you do with the cam, suggest you stick with the stock rockers. Budget performance rockers are not budget friendly when adjusters back out or they fatigue and crack. Stockers, if in halfway decent shape, will hang in great with a mild cam. Also low cost to replace them if needed.
