Lash caps #196023
01/17/09 01:22 PM
01/17/09 01:22 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
When do you need lash caps? I have always used them on any engine with .650 lift and over. Lately I've had a lot engines come in my shop with .700+ lift with no lash caps and no problems. I used to see lash caps on engines all the time and now I hardly ever see them. Is it still good to use them anyways or just overkill?
Re: Lash caps [Re: drag440] #196024
01/17/09 01:25 PM
01/17/09 01:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
People use them to correct rocker geometry.
In some cases they are no way around not using them, like when the rocker arm hits the retainer in certain Hemi projects
Some people use them when the push rods are to short, no matter what it does for geometry cause, lash caps are $25 vs $100-$200 for push rods..
Re: Lash caps [Re: drag440] #196025
01/17/09 01:34 PM
01/17/09 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve used em for years ESPECIALLY on small blocks where the geometry is crazy wrong. I`ve also been using em on my big block for better sweep w/my rpm heads and harland-sharp rockers. No problems ever.
Re: Lash caps [Re: drag440] #196026
01/17/09 01:54 PM
01/17/09 01:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With .700+ lift your going to see roller rockers
so you wont see the wear like you would without the
rollers(people use to use them to protect the vavle
stems and/or correct for the mismatch geometry).
I have used them in the past BUT I prefer not to,
its just added weight to the valve
Re: Lash caps [Re: MR_P_BODY] #196027
01/17/09 02:21 PM
01/17/09 02:21 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I currently use them on both my w-2 & w-5 motor but if every thing were right (geometry) I would pefer not to use them.If they come out you have a REAL problem.
Re: Lash caps [Re: DavidDean] #196028
01/17/09 05:57 PM
01/17/09 05:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I just bought a set for my SB because when I ordered the new cam I had them make it with .050 smaller base circle, this made it so I did not have to buy new pushrod's and also helped the geometry and sweep pattern on the tip.
Re: Lash caps [Re: dartman366] #196029
01/17/09 06:11 PM
01/17/09 06:11 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
20 to 30 years ago when everyone was running them, including me, very few people were running roller rockers and I was told big cams were hard on guides if you didn't run lash caps. Now with all the high tech rockers I guess you don't need them unless you have a geometry problem.
Re: Lash caps [Re: drag440] #196030
01/17/09 06:15 PM
01/17/09 06:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That would be my opinion.
Re: Lash caps [Re: dartman366] #196031
01/18/09 03:05 PM
01/18/09 03:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the base circle is reduced, the pushrod is now too short.
To correct this the valve must be shorter, not longer.
If this improved it, the geo was bad before but in the other direction.
Boffin Emeritus
Re: Lash caps [Re: polyspheric] #196032
01/18/09 03:18 PM
01/18/09 03:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the rocker stand's were a little high before and I did not mill them, by doing it this way I rolled the rocker inward with the smaller base circle/shorter pushrod's(because of the smaller BS) and added the cap's to take up the change and made the valve longer as the result of that change, which in reality helped correct the problem.
