95 dakota rear suspension #1958810
11/27/15 03:59 PM
11/27/15 03:59 PM
St. Peters, Missouri
dustemblue Offline OP
I just bought a 95 dakota to make my race project
Wanting to see what people are running for suspension and if they did anything for frame stiffness or boxed the frame in.
Re: 95 dakota rear suspension [Re: dustemblue] #1960052
11/30/15 01:01 AM
11/30/15 01:01 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The 95 frame is factory boxed past the trans crossmember Past the boxing, the C channel has 1" lips on both the top and bottom parts, and the C is slid into the boxed section a few inches and welded all around. As long as its not rusty, I don't see an issue with it twisting. It has rear leaf springs and would benefit from leaf spring improvements like any of the older Mopars. Gene
Re: 95 dakota rear suspension [Re: poorboy] #1960223
11/30/15 02:02 PM
11/30/15 02:02 PM
Thanks for the info. I will be taking the bed off this weekend to see what is all there. It has some different leaf spring perches on it
