Re: Sparking at Thermostat Housing on 1966 Sport Fury
[Re: Powerflow]
#1959903
11/29/15 09:01 PM
11/29/15 09:01 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
bolt the cable to STEEL/IRON! on the BLOCK or iron intake NOT to the aluminum housing/bolt or otherwise. It's smoking and sparking because it's a bad connection. It'll be hot if you touch it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Powerflow]
#1959905
11/29/15 09:02 PM
11/29/15 09:02 PM
amxautox
An impact can be good at breaking loose the corrosion of a stuck bolt.
Tom
author unknown
[Re: amxautox]
#1960200
11/30/15 01:17 PM
11/30/15 01:17 PM
Guitar Jones
An impact can be good at breaking loose the corrosion of a stuck bolt. They are also fantastic at rounding off the heads and breaking bolts off.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: NANKET]
#1960211
11/30/15 01:41 PM
11/30/15 01:41 PM
RapidRobert
then use a 1/2 breaker bar with an extension (piece of pipe works good) & jerk it rather than a steady pull (same principle why impacts work). Holler how it turns out & yes clean/relocate those cables!
[Re: Powerflow]
#1960293
11/30/15 04:28 PM
11/30/15 04:28 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
After 20 years the cables are probally junk.They might look OK but corrode on the inside.Like said bolt the ground to the block.That and heat the bolt as said.I used my 3/8 Impact a lot removing bolts thast were stuck.A good 6 point socket and some heat turn the power on it down and use some good penetrant.NAPA had/has good 1 gauge cables as factorys were light.If the bolt starts to move work it back and forth and keep heating and penetrant.ive also heated them and then melted bees wax into the threads.One reason I use antisieze on almost every bolt/nut.Rocky
Chrysler Firepower
[Re: QuickBpBp]
#1960399
11/30/15 07:59 PM
11/30/15 07:59 PM
RapidRobert
You can also try striking the head of the bolt with a hammer. I founds this works for me most of the times when a bolt is froze X2 X2, I totally forgot about that. that'd be the FIRST thing I'd do (hammer and a brass drift)
[Re: Powerflow]
#1961106
12/01/15 05:55 PM
12/01/15 05:55 PM
therocks
Niles , Ohio
Heating the bolt and then tossing ice water on it will work sometimes also.Never had any luck with smacking the bolt though.Too much rust in Ohio.Rocky
Chrysler Firepower
[Re: therocks]
#1961745
12/02/15 03:12 PM
12/02/15 03:12 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Heating the bolt and then tossing ice water on it will work sometimes also.Never had any luck with smacking the bolt though.Too much rust in Ohio.Rocky Rust, what is Rust I couldn't resist, please forgive me
