Re: Engine Wiring Harness from Year One
[Re: 68SportSatvert]
#1960722
12/01/15 03:23 AM
12/01/15 03:23 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
The one with the upgrade to factory electronic ignition has the wires for a dual field alt. i suspect that is the three wire alt you are asking about?
Its an excellent harness. Ive had several.
I want my fair share
[Re: SomeCarGuy]
#1960807
12/01/15 11:23 AM
12/01/15 11:23 AM
Posts: 1,014 LEE, MASS
TOMRR
LEE, MASS
Its an excellent harness. Ive had several. need to jump on this post I have same issue and have the harness with dual field alt what ballast resistor do I need I have the two prone type the harness has the four prone hook up ! Thanks Tom C.
#1961487
12/02/15 02:33 AM
12/02/15 02:33 AM
SomeCarGuy
Depending on the coil you have, you may be able to just jump it and skip having a ballast, which i have done. Guys get all hopping mad about this topic so...
