Engine Wiring Harness from Year One #1959121
11/28/15 04:26 AM
11/28/15 04:26 AM
KS
68SportSatvert Offline OP
KS
I am looking at buying an engine harness from Year One - I have a 30% off coupon. I have a 383 and am wanting to run a late model alternator and will use the bracket kit from Andy at AR. The harnesses are made for a late model alternator or the standard alternator. Has anyone used one to know how the late model one wires up? I want to make sure I get the correct harness and am unsure of which one to get to run the later alternator. I was under the impression that the later alternators were "one-wire" but the one used with the kit Andy sells uses an adapter that has 3 wires. I've read the instructions but, again I'm unsure which harness to get. Not trying to be dumb I just want to make sure I get what I need the first time. Thanks in advance!
Re: Engine Wiring Harness from Year One [Re: 68SportSatvert] #1959355
11/28/15 06:31 PM
11/28/15 06:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your best off contacting M&H wiring directly to get what harness info/identification PN# you need, you'll still need to purchase it thru Year One though due to licensing with M&H
Re: Engine Wiring Harness from Year One [Re: 68SportSatvert] #1960045
11/30/15 12:51 AM
11/30/15 12:51 AM
KS
KS
Thanks!
Re: Engine Wiring Harness from Year One [Re: 68SportSatvert] #1960722
12/01/15 03:23 AM
12/01/15 03:23 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
The one with the upgrade to factory electronic ignition has the wires for a dual field alt. i suspect that is the three wire alt you are asking about?
Its an excellent harness. Ive had several.
I want my fair share
Re: Engine Wiring Harness from Year One [Re: SomeCarGuy] #1960807
12/01/15 11:23 AM
12/01/15 11:23 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
need to jump on this post I have same issue and have the harness with dual field alt what ballast resistor do I need I have the two prone type the harness has the four prone hook up !
Thanks Tom C.
Re: Engine Wiring Harness from Year One [Re: 68SportSatvert] #1961487
12/02/15 02:33 AM
12/02/15 02:33 AM
Depending on the coil you have, you may be able to just jump it and skip having a ballast, which i have done. Guys get all hopping mad about this topic so...
