B1 Original Valve Cover fitment??? #1958154
11/26/15 04:03 AM
11/26/15 04:03 AM
Boise
thegodfather Offline OP
Boise
This is hard to believe but, I bought a new set of B1 Original heads and valve covers from Koffel's last year. Now I find out their newest valve covers that came with the heads don't offer the needed clearance for a MSD Distributor. Koffel's said they're still working on the VC problem but said a regular Chrysler distributor will fit with a crank trigger setup. Well I don't want a crank trigger setup due to the significant added cost. I want to use an MSD which I already have. A friend told me an older version of a B1 valve cover is different and would offer the right clearance with the MSD. Finding one will be the issue.
Any of you guys have some idea where a person can find valve covers that will work on B1 originals with an MSD distributor?
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958159
11/26/15 04:15 AM
11/26/15 04:15 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
On some of the heads the head itself interferes. Just grind a tad off the edge and it will work fine. A nuisance yes, but not a huge deal
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958163
11/26/15 04:26 AM
11/26/15 04:26 AM
Boise
Boise
Thanks Al for the quick reply back. I did grind a substantial amount off the valve cover and keep grinding until the MSD distributor would fit in place and rotate a tiny bit for timing. Now however, there's not much of the valve cover left to seal to the head surface. Maybe an 1/8" left to seal to the head. I'm pretty sure it won't seal up with such a thin amount on the valve cover left to seal w/o oil leaks.
I'm trying to figure out here how to attach a couple of pictures for you?
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958338
11/26/15 02:04 PM
11/26/15 02:04 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Tall or short deck? If you use a tall deck dist with the adapter in a short deck it raises the dist up where the valve cover requires very little clearance. On my tall deck motor I ended up buying a NRC offset dist. I think Indy sells them now but at a large mark-up.
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958384
11/26/15 03:14 PM
11/26/15 03:14 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
As Al says, it's usually just a light grind on the head and valve cover. It should have been fixed by now but as they say, that's racing.
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958723
11/27/15 12:27 PM
11/27/15 12:27 PM
IL
Dart451 Offline
Dart451  Offline
IL
I have a set of the old B1 valve covers just stumbled across them yesterday as I was cleaning the garage. I will go take a pic see if it's what your looking for
Re: B1 Original Valve Cover fitment??? [Re: Dart451] #1958738
11/27/15 01:00 PM
11/27/15 01:00 PM
IL
Dart451 Offline
Dart451  Offline
IL
Got them when I was trying to keep my combo secret so had the B1 milled off and told Mike to put his shop name on it
Re: B1 Original Valve Cover fitment??? [Re: Dart451] #1958769
11/27/15 02:12 PM
11/27/15 02:12 PM
Boise
Boise
Good Morning Dart 451. Thanks Much for helping me out and sending the picture.
I believe that's what I'm lookig for. They look correct.
The valve covers Koffel's sent me look like INDY valve covers with the B1 name on them. Anyways-YES I'm interested in buying them. Can you contact me privately?
Doug-
XmasTruck
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1958778
11/27/15 02:28 PM
11/27/15 02:28 PM
Boise
Boise
Here's my email address:
thegodfather_1963@yahoo.com
Doug-
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1959110
11/28/15 03:24 AM
11/28/15 03:24 AM
Las Vegas
Las Vegas
I have a set of those as well powder coated black. Not so easy to find these days for sure. But there are also 2 versions of those...
Re: B1 Original Valve Cover fitment??? [Re: Al_Alguire] #1959203
11/28/15 01:47 PM
11/28/15 01:47 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
What are the differences between those versions?
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1959582
11/29/15 03:55 AM
11/29/15 03:55 AM
Las Vegas
Las Vegas
One is tall and one is shorter. The tall ones are definitely not as easy to come by.
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1959591
11/29/15 04:20 AM
11/29/15 04:20 AM
MD
HEMI472 Offline
HEMI472  Offline
MD
do you have any pictures of the tall and short ones??? how much taller is it ??
Re: B1 Original Valve Cover fitment??? [Re: HEMI472] #1959894
11/29/15 08:46 PM
11/29/15 08:46 PM
Arizona
Chris'sBarracuda Offline
Arizona
I have a set of the shorties.. up
I mat part with them..
Chris.. wave
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1959904
11/29/15 09:02 PM
11/29/15 09:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what ratio rockers are you using
do 1.7 ratio work with the short valve covers
1.39 9.85 - 137 mph
Re: B1 Original Valve Cover fitment??? [Re: Ari440] #1959906
11/29/15 09:05 PM
11/29/15 09:05 PM
Arizona
Arizona
Mine worked with 1.7 T&D's and .850 lift. up
Chris.. wave
Re: B1 Original Valve Cover fitment??? [Re: thegodfather] #1959908
11/29/15 09:10 PM
11/29/15 09:10 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
thanks chris
1.39 9.85 - 137 mph
