Re: ? about the fuel system in my 93 Dakota
[Re: Dakotamecrazy]
#1958577
11/26/15 11:54 PM
11/26/15 11:54 PM
Posts: 2,046 ky.
kenworth_goose
ky.
Thanks poorboy! I was figuring on a regulator and I am going to use a Edelbrock Airgap intake along with a 750 carb. I just was not sure about the tank, pump and lines. Because if I had to change all of it I was thinking of going E85. One thing I will have to find is a linkage bracket for the throttle and ATV cable. I would like to keep the overdrive if possible and will need a bracket if one is made. If not I guess we can figure something out.
Thanks Chris Just change the cable to a linkage from a 727. It fits right on the trans. shaft.
[Re: kenworth_goose]
#1958589
11/27/15 12:24 AM
11/27/15 12:24 AM
Posts: 25 Ohio
Dakotamecrazy
Ohio
Thanks Chris Just change the cable to a linkage from a 727. It fits right on the trans. shaft. Thanks Kenworth_goose! I will have to look into that.
#1958739
11/27/15 01:02 PM
11/27/15 01:02 PM
DaytonaTurbo
Manitoba, Canada
I can't say if it's true, but I have heard high pressure fuel pumps for port EFI often don't live long when run at low PSI carb fuel pressure. Now whether that's true or whether that's the result of running an EFI pump with a non-return style regulator, I can't say. I would say a return style regulator is a must as EFI pumps cool by fuel flow. I put a carbed 360 in an 89 Dakota a few years ago and If I remember right the regulator was set at 5 lbs. and I ran a return line back to the tank which it already had the return. It worked perfect and kept the fuel circulating all of the time as the pump ran all of the time. It never vapor locked or ran out of fuel. I ran a valve on the return line and slowed the fuel to the tank down. It worked perfect. Had people tell me it wouldn't work but it never lost any pressure, and never gained any either. Held a steady 5psi all of the time. Didn't matter if I was driving normal or beating the eye balls out of it. Had a gauge on the cowl. Sounds like a nice setup! Although in all fairness, in stock form your TBI fuel pump wasn't putting out a whole lot of pressure either. 13, 15, something like that was TBI psi.
[Re: DaytonaTurbo]
#1958816
11/27/15 04:15 PM
11/27/15 04:15 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
I can't say if it's true, but I have heard high pressure fuel pumps for port EFI often don't live long when run at low PSI carb fuel pressure. Now whether that's true or whether that's the result of running an EFI pump with a non-return style regulator, I can't say. I would say a return style regulator is a must as EFI pumps cool by fuel flow. I put a carbed 360 in an 89 Dakota a few years ago and If I remember right the regulator was set at 5 lbs. and I ran a return line back to the tank which it already had the return. It worked perfect and kept the fuel circulating all of the time as the pump ran all of the time. It never vapor locked or ran out of fuel. I ran a valve on the return line and slowed the fuel to the tank down. It worked perfect. Had people tell me it wouldn't work but it never lost any pressure, and never gained any either. Held a steady 5psi all of the time. Didn't matter if I was driving normal or beating the eye balls out of it. Had a gauge on the cowl. Sounds like a nice setup! Although in all fairness, in stock form your TBI fuel pump wasn't putting out a whole lot of pressure either. 13, 15, something like that was TBI psi. A 93 Dakota would have had the Magnum v6 or v8 and would have been port injected. pump PSI was in the 50 lbs range. You definitely need a regulator with a return line or the pressure will deadhead against the regulator and will increase the pressure at the carb. (my son didn't believe me and got to buy 2 regulators, the cheap one without the return, and the expensive one that worked. Gene
